8 hours ago, Captain Obvious said:
I suspect the reason for those two photos was to point out the differences in the positions of the wheels in the two wheel wells. Yikes.
Yeah, it's off a tad.
Just to echo someone else's comment, I find that Z program fascinating as well as any tidbits that keep coming to light years on. I did benefit from it in one way. When Nissan fired the spare parts machine up I believe they must have minted a bunch of new front fenders because I bought two new ones over the local dealer parts counter for a steal. They came stickered with Nissan parts numbers so I've always assumed they were from the original tooling. 🤷
20 hours ago, Zed Head said:
The seller uses the typical "Series 1" terminology but then doesn't know where the firewall VIN is stamped. Lesson for owners - find a knowledgable seller if you want to get maximum value from your car.
'Course the guys who REALLY know their onions know that the bodyshell's individual identity is ENGRAVED on the firewall, not stamped...
I've wondered about the stamping/engraving. As somebody who has worked with both stamping and engraving, it's incredible to me how Nissan was able to make engraving look like stamping back in the 70's. I assume that they used a pantograph to get the precision. No way that it was done free hand. Also odd that a pantograph can't hold a straight line.
It would be very cool to see some of the tools they used back then.
https://www.hotrod.com/how-to/where-is-the-vin-number-on-a-car
It seems reasonable that Nissan might have started with engraving then moved to stamping.
Or maybe somebody can show or explain why the engraving looks like stamping. That would be the most helpful. For people who have actually seen both and understand the processes. Engraving removes metal. Stamping displaces it.
I got curious so I looked in the GI pages of the FSM's. 1972 seems to be the first time they describe the stamping of the identification number on the firewall (cowl).
1970 and 71 don't mention it, that I can find.
1970
The process involved aligning a fixture to the firewall of the unpainted bodyshell (other Nissan vehicles had the identity elsewhere - for example my KPGC10 Skyline GT-R has it on the LH door sill) into which the full combination of chassis prefix and body serial number was dialled-in by the operator, and then the machine did its thing. We have seen examples of mistakes (operator error...) which have been 'corrected' by the same process and then authenticated with a Nissan 'hamburger' cipher.
We can play terminology tennis between 'stamping' and 'engraving' to our heart's content but the process used was - I believe - more correctly described as 'Dot Engraving', where a punching point deformed the metal into the desired letters and numbers in the distinctive Nissan font of the period. This method - although in a much more developed and computer-controlled form - is still in use today. Here's a modern version of the machine (on the dreaded Ali Express, no less...) with a playable video:
https://www.aliexpress.com/item/1005007340921417.html?dp=CjwKCAjwp_LDBhBCEiwAK7FnkgNg_pgoKEwp2vl_LmTjbAZXtPHK3lxpnCZE8Rsz8cmrvpF30NaRhxoCKVwQAvD_BwE@254613&isdl=y&aff_fsk=_okqVOWy&src=delupeUK2025&aff_platform=aff_feeds&aff_short_key=_okqVOWy&pdp_npi=4%40dis%21GBP%21616.83%21585.99%21%21%21%21%21%40%2112000040338251243%21afff%21%21%21&cn=254613&cv=466926&af=
I would imagine that the somewhat laconic and haphazard nature of the late 60s Nissan Shatai results was symptomatic of the machinery being used. I wouldn't rule out the possibility that it was - along with Nissan's distinctive font - intentionally difficult to tamper with/replicate/forge.
Anyway, the big point here is that when people talk about 'firewall stamping' and 'VIN stamping' it calls to mind old-fashioned letter and number stamps that would be whacked with a hammer to make their mark. Doing that on an unsupported firewall (the other side is in the cowl well...) would be pretty difficult without big deformation, and if supported it would require some other kind of fixture on the other side. In my KPGC10'S case it would be impossible on the (blind) door sill. I'd like to see a machine that could physically 'stamp' a firewall VIN on an S30 in one go (I'm imagining it to be steam-powered...) but the whole thing sounds far too impractical. The dot engraving machine seems to have been a lasting solution.
This is actually a subject which we have discussed previously here on the forum. @kats even came up with a photo of the same fixture still being used on late 1980s and early 1990s Nissan Silvias (S13/S14?) but - of course - I'll be damned if I can find the thread and the image. Don't know why this place is so hard to search for something I know is here.
S30 chief engineer Hitoshi Uemura gave me a copy of a period Nissan document which showed the positioning instructions for the chassis number fixture, but I was asked not to publish it (and I'll honour his request).
Not on the S30-series Z's firewall.
'Dot Engraving' displaces metal rather than removing it. In the case of the letters and numbers we are discussing, the dots are so close together that in close-up they look like one continuous form. The deformation is visible in the reverse side of the panel. The firewall sheetmetal on the S30 is thin enough gauge that some deformation of the surrounding metal occurs (noticeably more on some letters and numbers than on others) so it is all too easy to imagine this is the result of physical - 'one blow' - stamping. It isn't.
Here's a bare metal example of a Nissan S30's firewall '3' number, showing front and rear. This is classic close-form Dot Engraving:
Edited by HS30-H
