9 hours ago, 240ZBUILTBYME said:
Well sorry it’s taken time to get back to updating the needle sitcho. (Oz slang for situation)
but this little thing has been keeping me busy, she arrived last week. 😍
But I did get round to trying to get the needles out, I decided to first try some rubber and some vice grips as it was the easiest to conjure.
And long story short it worked! Just needed the grip  of the rubber to apply enough torque to twist it free!  The second needle came out by hand.
One of the needles had N27 on it, the other had nothing. I believe these are 240z needles?
Ryan
Congratulations Ryan, especially for the arrival of a healthy child.
Awesome!
@tyroguru @Racer X @Patcon @240260280 @Captain Obvious
Thanks heaps fellas! It’s the greatest project of them all!
Congrats on the new baby! Your folks must be thrilled too. They probably bribe you for shed space. Have to bring the grandkids when you work on the car.
Thanks mate! Yeah that’s it!
3 hours ago, Patcon said:
Kids are amazing projects but you might find you grow as much as they do...😉
Very poetic patcon! They are amazing, my two year old is certainly making me grow into a more patient man...😜 it’s funny how you can find them the most annoying thing ever, then a split second later the most adorable.
so despite my daughter arriving I managed to make it to the car to do a bit of spannering, stripped the drum brakes and gave them a clean out, also got the front suspension assembly broken down and ready to bring all components in need of a press to my mates shop.
I still haven’t decided if I’m going to rebuild drums or go straight to discs. Any thoughts or opinions?
AB295B08-2257-46AF-8E8F-0E5AEC9639F1.thumb.jpeg.c79cc6e24fa8c63be3dce1ea0e86d6ff.jpeg0B8BBC6B-A745-471A-A036-305EFDFEB1A7.thumb.jpeg.3ccda6fbad1b4a0b7a36429f2720657a.jpegFC0578FA-F300-4BC8-972F-3ADD152D28AC.thumb.jpeg.2461552bcfa46e3fb48374bf26db4380.jpeg
not sure which is an original 240z cylinder, anyone know off hand?
After wire brushing the crud off the rear control arm looks like some smart fellow tried to put a jack stand under it. I was thinking I would just finesse the dents straight if I can.
Outer tie rods were jammed in tight, haven’t tried heat yet but figure I’ll just press them out along with everything else. So just dismantled steering rack at the knuckle.
9B65D334-56E5-46D9-B847-F8B194C39E0E.thumb.jpeg.21b26c5f6d306f10bf5697bfade3af66.jpeg6C8E4E20-0EA8-429C-84B0-3D2BFA7CBBDF.thumb.jpeg.c6b4c0a66463a01289da8f55a2524dd1.jpegF5BCE06A-D794-48FC-B66D-37E12432F846.thumb.jpeg.6ab2cab6f01d9feaf4dec2887feafa9a.jpeg
anybody know if the silver brackets from the steering rack bushes are meant to be there? They looked like diy aluminum shims  made up.
I agree, I would try to straighten out the damage on the control arm.
Haven't seen the shims before
Most rear brake upgrades dont increase brake efficiency. Some can throw off the F/R bias and increase stopping distance. All that said I am going with rear disc because they are self adjusting.
Uhhhh... So are the rear drums.   Haha!!    :ph34r:
I know, I know...
But I find they dont always adjust as designed and the pedal stroke gets longer to take up the space. The discs really dont have that issue
I know. You are absolutely right. They are supposed to adjust, but they usually just don't.
In order to get rear drums that really do adjust, you need to get away from that goofy floating cylinder design and swap over to the 77-78 style or do a rear disk mod.
