March 30, 20187 yr Author comment_546063 @w3wilkes Thanks for the travel tip. The route sounds interesting - If I'm down there again, I'll try it. I had not heard of Levan, Utah before so I googled it. Neat pictures. I imagine real estate is quite reasonably priced in Levan. Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546063 Share on other sites More sharing options...
March 30, 20187 yr comment_546084 @Richard McDonel Glad to help and find that the issue is resolved for you Richard! Those Kyosan Denki mechanical pumps are very rugged and reliable---it just made no sense that one would go bad after sitting in a box and then only being run for 20 minutes or so. 5 hours ago, Richard McDonel said: Zup Frosquisher (Come on, that's not your real name? Is it?) No--there's a story behind this------ Carl Stahlnecker (Bambikiller) was a respected member of this forum many years ago before his shockingly sudden death. I still dearly miss Carl. His numerous posts were among the most informative I have ever read. Carl really knew his stuff about Z cars and was always very helpful, but often opinionated and direct. His screen name--- Bambikiller--- came after an incident between his 240z and a deer. I ran over a frog one rainy night in my 240z and lamented the poor amphibian's demise. In homage to Carl I suppose, I chose "Frogsquisher" as an adjunct to my screen name Zup. Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546084 Share on other sites More sharing options...
March 30, 20187 yr comment_546089 Yes the high number is correct. Some blue loctite on that bolt and the two small bolts that hold the end plate on are recommended. Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546089 Share on other sites More sharing options...
March 30, 20187 yr comment_546105 Going through the various on-line FSM pdf files for the various years this morning, and sure enough, at least the 71 and 72 manuals list the "camshaft gear bolt" torque as 36-43 ft-lbs. The 73 manual if finally correct at 86-116 ft/lb Holy "engine destroyer" batman.... Edited March 30, 20187 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546105 Share on other sites More sharing options...
March 30, 20187 yr comment_546106 And even if the lack of fuel pumping was caused by the eccentric, there should still never be fuel leaking out the back of the fuel pump. So make sure you double check that pump before you consider it good. Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546106 Share on other sites More sharing options...
March 30, 20187 yr comment_546141 3 hours ago, zKars said: The 73 manual if finally correct at 86-116 ft/lb Confirmed by an alternate source: Page 24 in How to Rebuild Your Nissan/Datsun OHC Engine by Tom Monroe states -- Torque the cam-sprocket bolt 86-116 ft-lb (12-16 kg-m). Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546141 Share on other sites More sharing options...
March 30, 20187 yr comment_546169 Earliest engine manual "Model L24 L20A Series Engine" has error in photo but correct value in specification table. 5 to 6 kg-m is incorrect for both Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546169 Share on other sites More sharing options...
April 2, 20187 yr comment_546423 On 3/27/2018 at 9:57 AM, Captain Obvious said: Zactly. Ed Zachery. A woman was very distraught at the fact that she had not had a date, nor any sex, in quite some time. She was afraid she might have something wrong with her, so she decided to employ the medical expertise of a sex therapist.Her MD recommended that she go see Dr. Chang, the well-known sex therapist. Upon entering the examination room, Dr. Chang said, "OK, take off all your crose." So she did."Now, get down on all fours and crawl reery fass to the other side of loom." So, she did.Dr. Chang then said, "OK now crawl reery fass to me," so she did.Dr. Chang slowly shook his head and said "Your probrem vewy bad. You haf Ed Zachary Disease... worse case I ever see...that why you not haf sex or dates."Confused, the woman asked, "What is Ed Zachary Disease?"Dr. Chang replied, "It when your face rook Ed Zachary rike your arse." Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546423 Share on other sites More sharing options...
April 2, 20187 yr comment_546452 Haha!! Yes! That's the one!! So clearly, once again, you have shown that you and I have the same arsenal of jokes. Stupid immature 13 year old humor. One may follow the above joke up by jumping out from behind the stack of boxes and yelling "SUPPLIES!!!" Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546452 Share on other sites More sharing options...
April 2, 20187 yr comment_546473 Or say it twice like Gomer, supplies! supplies! Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-546473 Share on other sites More sharing options...
April 9, 20187 yr comment_547001 On 27/3/2018 at 9:49 AM, Captain Obvious said: And that should STILL only be used as a preliminary set-up method. A direct verification of the level is the only way to be sure, and is the gold standard for accuracy. I tried for .55 inch and it was still lean. The gap should be at less than that. Link to comment https://www.classiczcars.com/forums/topic/59769-sus-and-pumps/?&page=3#findComment-547001 Share on other sites More sharing options...
