Yup. Patience is key. I spotted a couple flaws that will need touching up before seal coat too. As expected...!
I'll absolutely give you a high-five! With the current exchange rate, does that work out to a high-seven and a half or something by the time it gets to you?
I love the crisp body line down the whole side. Especially where bodywork often muddies it out over the rear wheel arches. Looks great!
Thanks guys! I’m glad I got my MSA order in last month! Saved about $50 in exchange rate. Still a few things to order but I’m gonna wait till the dollar recovers a bit.
First pass of the long block over the hi build on the door. The dent and repair took many hours of sanding and filling, but now I see it was all worth it! Flat!!!
All sanded. Feels smooth like glass! Now to wash the whole car with soap and water, then re-mask the car and spray sealer before the base coat.
  • Popular Post
Seal coat sprayed this morning !
The finish was good but not smooth as it was before I sprayed the seal coat. So I broke down and sanded it all down again with 1000 grit, just enough to bring the glass like feel to the panels again. Tomorrow is the day for paint!!
