jalexquijano Posted November 28, 2014 Share #1 Posted November 28, 2014 My 240z presents some window rattling on the driver´s door when i drive. If you close the door with the window fully down it sounds as if the window will fall. What could be missing? Any kit that sells all the inner seals, Windows felt, etc? Link to comment Share on other sites More sharing options...
Sean240Z Posted November 29, 2014 Share #2 Posted November 29, 2014 The window rollers are notorious for breaking off. If you can't see it when you look down into the window door opening, it's probably in the bottom of your door. MSA has the window roller and the door window channel seals. http://www.thezstore.com/page/TZS/PROD/30-2151http://www.thezstore.com/page/TZS/PROD/classic03a05/34-1052A Link to comment Share on other sites More sharing options...
jalexquijano Posted November 30, 2014 Author Share #3 Posted November 30, 2014 The window rollers are notorious for breaking off. If you can't see it when you look down into the window door opening, it's probably in the bottom of your door. MSA has the window roller and the door window channel seals. http://www.thezstore.com/page/TZS/PROD/30-2151http://www.thezstore.com/page/TZS/PROD/classic03a05/34-1052AThanks Sean, What else would you recommend replacing besides the window rollers and door window cannel seals on both doors? I just want to make one sole order. Link to comment Share on other sites More sharing options...
