5 hours ago, chaseincats said:
Gotcha, I'll halt the screw hunt. How do I gain access to the area with the adjusting wheel on the back?
I really thought the access was through the backing plate that the brake pads are attached to. Seems like there's a rubber oblong plug that you pull for access to the cog wheel to back the pads off.
Wait i thought the cog was accessed through the hole on the front of the drum?
That should be it in the red circle.
I saw my OE aluminums the other day cleaning up my storage building and they still have the rubber plugs in them.
Had to resort to the old drum puller once.
Came off with a very loud bang.
Putting on a couple of lug nuts loosely prevents it from exploding into your lap
Edited by zKars
Mine has 2 of those holes - does it matter which I use?
