Rear Drum Cover Removal? - Help Me !! - Classic Z Car Club Skip to content
Hi all -
I have a leaky right rear wheel cylinder and can't figure out how to get the rear drum off and the FSM basically says 'take it off.'
On most cars, there's a lock screw somewhere then you just smack the cover and yank it off but I can't find that screw and its driving me nuts lol
Anyone have an idea?
-chase
If the brake isn't locked up, and the wheel turns, the likely cause is rust between the axle flange and the brake drum. I'd use a few long penetrating oil soaks and use a hammer to hit the drum between the wheel studs a few times. My next choice would be heat.
Yep the wheels turn fine. Isn't there a lock screw that holds the drum on?
Actually...
32 minutes ago, Zed Head said:
Actually...
So I crank the shoes in and the drum should come off? All of the other car drums I've worked on have a locking screw that needs to be removed first...
Z's don't.
No guarantee that the drums will come off even if you back the adjusting wheel off. People have had to sacrifice the drums if they're really stuck. But, the best place to start is the instructions in the FSM. Back off the wheel, see what happens.
Edited by Zed Head
7 minutes ago, Zed Head said:
Z's don't.
Gotcha, I'll halt the screw hunt. How do I gain access to the area with the adjusting wheel on the back?
There's a hole in the brake drum. Had a rubber plug in it. Might still be there.
Mine actually has 2 holes on it which is weird since all of the drums I've seen online only have 1. So I just spin the drum until the hole is near the wheel cylinder then use a small screwdriver to turn the shoes in?
If the light is right you can probably see the notches through the hole. In practice you just jam a small screwdriver in the hole until you feel it grabbing the notches of the adjusting wheel, Keep jabbing to get the wheel to move. It's kind of tedious, you don't get much movement per unit of effort.
Sounds good - I'll give it a shot. Thanks
