15 minutes ago, Patcon said:
The cowl panel should not be removable with fenders on. There is a flange on either end with two large screws threaded into the body. Those screws are under the fenders
This Cowel only had screws that were accessable from under the hood then had tabs that were held inplace with some rubber inserts... besides the welded edges to the fender. lol
Edited by Toiletduck34
21 minutes ago, Yarb said:
So, Trying to go on my weak short term memory, How would you service the wiper motor etc? You have to basically remove the fenders?
The wiper motor is under the cowel, i think he has it mixed up that you cant take off the fenders without taking off the cowel. there are 2 large bolts holding on the fender under the cowel.
