I'm not sure. I saw that Z Car Depot recently started selling something similar though. Not as fancy as the float sync, but should do the same job. I bought some fittings that do essentially the same thing as this Z Car Depot product. https://zcardepot.com/collections/240z/products/su-carburetor-float-fuel-level-setting-tool-240z
That little adapter hose with the banjo is great for later round tops with the drain fitting. Same for the float-sync device.
If you have earlier carbs without the drain, a little piece of tubing on the bottom of the bowl works. Down side is you can only use it static with the engine off.
