Float sync device - Carburetor Central - Classic Z Car Club Skip to content
Float sync device
Yeah these are out of production for some time now.
For $8.00 to buy this simple device, who cares that the Float-Sync is no longer available eh?
That little adapter hose with the banjo is great for later round tops with the drain fitting. Same for the float-sync device.
If you have earlier carbs without the drain, a little piece of tubing on the bottom of the bowl works. Down side is you can only use it static with the engine off.
Here's a very familiar picture, I'm pretty sure Zkars put up for us, that shows where the fluid should be. The top of the rectangle.
Edited by siteunseen
