5 hours ago, f1d094 said:
Just a gut feeling, but based on the how-and-where-and-how-hard I tap on the ECU/connector, it seems like there might be a break in one of these coils...
Alternatively, based on your comment about the darlington transistors, is this any sort of failure mode that makes sense for them? Where rattling or knocking with make them fail temporarily?
The input filters could certainly become intermittent if vibration has taken it's toll. You could put meter across the visible wire coming off one side of the input choke coil and it's corresponding ECU connector pin. Should be pretty easy to figure out which pins they are filtering. Many of them are dead shorted, but the few (three?) that have the coil installed should be easy to determine.
Looking at the approximate positions of the filters on the board and the pin functions of the ECU I/O connector, I'd guess that the filters are on pins 7, 27, and 13. Those would be inputs to the ECU that would be susceptible to noise. Those pins are 7) the AFM slider, 27) the air temp input, and 13) the water temp input signals respectively. But of course, that's a guess from across the interwebs.
Here's a crude sketch I whipped up bunch of years ago. I know this info is available in other forms, but this form made sense to my brain:
So about the failure mode for the Darlington outputs... No, they would probably not fail in the mode you are seeing. HOWEVER, the solder joints TO those transistors could fail with the symptoms you are describing. Any solder joint on the board could potentially go intermittent over time, but it would be unlikely for most of them. Vibration, stress, and temperature would be the risk factors.
So about those risk factors... The reason those output transistors are so big and bolted firm to the chassis is that they get hot. There's your heat risk factor. And the I/O connector gets mechanically stressed every time you move the wiring harness or attach/detach the harness to the ECU. There's your stress factor there.
Bottom line... If I were looking for a failing solder joint, I would start at the I/O connector and the output transistors.
However, all that said, if I'm placing a bet at window #3, I'm betting the root problem is not inside the ECU case.
It might be fun to run with the ECU cover off. When you kick the case all of the components feel it. With the cover off you can pick the one you want to test. Hit it with a hammer, wiggle it, whatever. It is odd though that two ECU's would have identical failure characteristics.
Might be worth the tme to do a pin drag test on the active pins in the connector that CO shows in his diagram. Maybe you have a loose one.
Many thanks to you both. I love the idea of testing with the lid off, I should have thought of that. Since the refurb unit won't be here until mid-week I think what I will do in the interim is the following:
1) Assuming I have enough connectors in my bins, make 26 individual extensions so I can "plug the harness" without actually attaching it to the ECU
2) Install the ECU sans case, but connected with my 26 little piggies
3) Run the system
4) Thump the free-floating harness plug
5) Wiggle/Tug every individual connection
6) Use a spudger to do delicate tap/wiggle tests on every little thing inside
This should be interesting.
Edited by f1d094
Actually, I should first do what @Captain Obvious suggested and check the choke coils. Then the above. I'm afraid I have honey-dos today so this will have to wait until tomorrow but I'm sure everyone is on pins and needles...
16 hours ago, Yarb said:
I have to ask why not just
Because the curious mind must KNOW.
For me, owning a classic car is really the journey. I get great satisfaction from understanding all the ins-and-outs of...well, anything. If I drive it, fly it, sail it, race it, ride it, eat it, grow it, run it in my house or office, or if it has moving parts or does anything that impacts my life in any meaningful way, I am driven to know how the thing works, and/or how to build/repair/grow/write/create my own.
I like making things.
