Monday at 02:49 PM2 days Author comment_677824 Just a couple links for anyone who lands here in the future:https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/282195-2?qs=tAlKl34sQZvipf6sMzAM1Q%3D%3D&srsltid=AfmBOopeu97zCLCKVjc6MLBwsS4YlfJZ3U0vIRUzRHNCUAktrArMAGhihttps://www.te.com/en/product-282195-2.html Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677824 Share on other sites More sharing options...
Monday at 02:56 PM2 days comment_677825 1 hour ago, f1d094 said:I'm generally familiar with the brown-out condition the Z's ran under due to an undersized alternator or so it was explained to me when I replaced my headlight switch assembly..I was talking about a different problem. You'll know it if it happens.On the loose pins, if it was mine I might put a slight twist on every male pin in the ECU. Increasing effective width. I'd have to check the contact points to be sure it would work though. On to the next problem. Might as well get ready for the failing ignition module. It's a high probability. Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677825 Share on other sites More sharing options...
Monday at 03:14 PM2 days Author comment_677828 7 minutes ago, Zed Head said:I was talking about a different problem. You'll know it if it happens.Oh? Do you mean above and beyond burning out the internals on the selector and high-beams swtiches? Do you think this is something to be concerned about now that my power draw has been dropped so much?11 minutes ago, Zed Head said:put a slight twist on every male pinGENIUS. I was literally just now chatting with my wife about how I can either make the female sides more grabby, or the male sides "fatter". Did not think of twisting to accomplish this. I will keep that one in the arsenal, thanks! Now I just need to get the harness connector disassembled and verify root cause.13 minutes ago, Zed Head said:failing ignition moduleI already have a spare...which might actually be in the car now (ref. prior comment somewhere). I had an unrelated issue several years ago and put in a new one but the old one tested out great. Uncertain which is in the car now. If I remember I'll open the box in my parts bin and see who's hiding in there. Edited Monday at 04:23 PM2 days by f1d094 Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677828 Share on other sites More sharing options...
Yesterday at 01:19 AM1 day comment_677836 I had something similar on my L28ET that turned out to be a cracked solder joint on a connector pin. It drove me crazy for months, very random. Much like yours sometimes it would restart right away, sometimes take a few to several minutes to restart, didn't seem to be temperature related. Mine was not on the ECU but on the CAS optical unit in the distributor so that the ECU wouldn't always get the proper timing signal. You might look at the distributor (cracked magnet?) or the Electronic Ignition unit, or maybe the ECU connector solder to the board, maybe the EFI Relay or power to the ECU. Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677836 Share on other sites More sharing options...
Yesterday at 08:47 PM1 day Author comment_677872 @Captain Obvious - When disassembling the harness connector one end of my gasket crumbled. You seem to have some quality Kung Fu in the electronics parts department. Any idea where I might find a replacement? I found this but no dice on the individual component. Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677872 Share on other sites More sharing options...
Yesterday at 09:00 PM1 day Author comment_677873 For future someone who also needs to disassemble their harness connector:MAKE A NOTE: that here are two long plastic retaining comb-clips that hold in ALL of the pins on each side. It doesn't look like it wants to fall out, but it is pretty loose and if it falls out all your unlabeled connectors are coming tooCut the zip tie and remove tape from the harness/connectorRemove the small retaining screw located on the end of the connector by the hook/hingeUse a plastic spudger to run around the edges of the rubber gasket inside the connectorSlide the cover away from the harness Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677873 Share on other sites More sharing options...
Yesterday at 09:03 PM1 day Author comment_677874 Things I wish I knew before I started!Next step will be to put everything back in place but leave the cover off the harness plug and do some wire-wiggling/tapping that way. Starting this way would have been the Pro-Moveâ„¢Live and learn... Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677874 Share on other sites More sharing options...
22 hours ago22 hr comment_677880 4 hours ago, f1d094 said:gasket crumbled. Any idea where I might find a replacement?I haven't seen the gasket separately. but if the whole connector shell is only a couple bucks, why not buy one and strip out the gasket?Couple pics to go with your text above. The red oval seal is what you're looking for, right? And these are the plastic retainer strips you mentioned maybe? Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677880 Share on other sites More sharing options...
5 hours ago5 hr Author comment_677909 Yes, and yes. At first I wasn't able to find someone who would sell me just one (I often have problems loading mouser.com, arrow.com, and any other edgesuite protected sites. I am a hacker/bot, apparently) but it looks like digikey just loaded for me and I can have for $14 incl shipping Edited 5 hours ago5 hr by f1d094 Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677909 Share on other sites More sharing options...
2 hours ago2 hr comment_677912 Ah, step on out you have gone this far! Educational purposes of course for the rest of us!!! Link to comment https://www.classiczcars.com/forums/topic/69483-kick-your-ecu/?&page=4#findComment-677912 Share on other sites More sharing options...
