Posted Yesterday at 11:47 AM1 day comment_676332 I've often seen pictures posted by CZCC members where their Z is perched up on axle stands, front and rear. Getting a car up on stands at either the front or the rear is easy. I'm curious to know what the accepted wisdom is for getting the other end elevated and then getting the stands extended to full lift. Can it be done safely in one step, or is it better to start with the axle stands at minimum extension and then go back and forth in steps from front to rear until both ends are up all the way (i.e. the axle stands at maximum extension)? Link to comment https://www.classiczcars.com/forums/topic/69402-axle-stands/ Share on other sites More sharing options...
Yesterday at 12:59 PM1 day comment_676333 Good topic. My thinking is that it's better to go in a few incremental steps, going front to back. This method minimizes subjecting the jack stands to axial (horizontal) loads. The rating on jack stands in only for pure vertical loads. Link to comment https://www.classiczcars.com/forums/topic/69402-axle-stands/#findComment-676333 Share on other sites More sharing options...
Yesterday at 04:04 PM1 day comment_676335 It is safer to go back and forth; setting one end low before jacking the other end high and going back to raise the lower.Does anyone know of / recommend stands that support the car on the lug studs with the wheels off? Link to comment https://www.classiczcars.com/forums/topic/69402-axle-stands/#findComment-676335 Share on other sites More sharing options...
23 hours ago23 hr comment_676336 https://technotoytuning.com/garage/parts/techno-toy-tuning-hub-stands?srsltid=AfmBOopa6jRW6cUSQ9PXFDILN9oYNqUzVHqm3tx5nVKNJKdkWBs52W8E Edited 23 hours ago23 hr by zKars Link to comment https://www.classiczcars.com/forums/topic/69402-axle-stands/#findComment-676336 Share on other sites More sharing options...
22 hours ago22 hr comment_676337 Pretty cool. A bit pricey Link to comment https://www.classiczcars.com/forums/topic/69402-axle-stands/#findComment-676337 Share on other sites More sharing options...
20 hours ago20 hr Author comment_676338 Thread highjacked. Start a new topic if you want to talk about hub stands. Link to comment https://www.classiczcars.com/forums/topic/69402-axle-stands/#findComment-676338 Share on other sites More sharing options...
