June 27, 20241 yr comment_666821 I chose the Trophy because that’s what you deserve for being an educator friend. Congratulations Sir! Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-666821 Share on other sites More sharing options...
June 27, 20241 yr comment_666839 13 hours ago, Yarb said: I chose the Trophy because that’s what you deserve for being an educator friend. Congratulations Sir! Second that. Not an easy job: 1/3 educator, 1/3 keeper-of-order, 1/3 entertainer. Made all the more challenging in this modern era of cell phone and texting distractions. Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-666839 Share on other sites More sharing options...
June 27, 20241 yr comment_666857 Congratulations on finishing your teaching career. I retired from teaching 14 years ago and every June I like to watch this video. Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-666857 Share on other sites More sharing options...
June 28, 20241 yr Author comment_666870 16 hours ago, psdenno said: Congratulations on finishing your teaching career. I retired from teaching 14 years ago and every June I like to watch this video. Lol - my co-workers were singing that to me - emphasis on "Schools Out Forever" 😁 Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-666870 Share on other sites More sharing options...
June 29, 20241 yr Author comment_666876 Getting the truck ready for another Ithaca trip, and a short one to Kingston, NY tomorrow - I got a new windshield installed today - the old original one was so pitted driving at night was a nightnmare New wheels & 2 new Bridgestone Potenza T005's for the C30 came - so I got those mounted. Need to check the toe old one new This is what I drove home on last Sunday Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-666876 Share on other sites More sharing options...
July 1, 20241 yr comment_666974 On 6/26/2024 at 8:16 PM, HusseinHolland said: Today was the last day of my teaching career. I'm officially retired 🤪 Got a little wiring on the south wall - finished up the wiring of the 240 & 120 receptacles Used crimp eyelets for the grounds wired each receptacle separately rather than bridging them 12AWG for the 20A receptacles Made sure they were the right version 240V outlet this time 10AWG for the 240V 10WGA Junction that feeds the East center post receptacle Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-666974 Share on other sites More sharing options...
July 9, 20241 yr Author comment_667168 Broke down & bought an OEM fuel sender from ZcarDepot - I've gone through two different aftermarket senders, and both leaked around the sender pins. Installed it today Hopefully the end of my gas smells Edited July 10, 20241 yr by HusseinHolland typo Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-667168 Share on other sites More sharing options...
July 10, 20241 yr Author comment_667201 While I'm in wait mode for the TUS-11a Ujoint, I cleaned up the floors & undersills where the undercoat was either non existent or damaged, and primed exposed areas, then stone chip protection then undercoat. Have to wear a coat & respirator - this stuff is nasty. The ambient temps are in the 90's, so I think I lost about 5lbs in water weight by the time I was done. Area that was beaten to fit the 350Z seat wire-brushed the original undercoat & soaked with some turps to soften up the old stuff. Chipped off the loose bits. Replacement (warranty) tension rod bushings came, so I pout those in also Edited July 10, 20241 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-667201 Share on other sites More sharing options...
July 10, 20241 yr Author comment_667262 Still waiting for Datsun parts. So, I started fixing the rust on the Volvo pickup right rocker panel. Driver's side has no issues. Pretty bad. It was bad when I got the wagon 3 years ago started poking from the inside cut most of the outer skin off have to fix the inner structure before I can replace the rocker skin. This mid section below the captive nut is the reinforcement for the B pillar, all this has to be replaced Scraped all this sealant/undercoat back from the floor to rocker lip, to make sure nothing will catch fire when I start welding in new sections Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-667262 Share on other sites More sharing options...
July 12, 20241 yr Author comment_667313 Scraping away at the underside where I will need to make a cut Shoulder gets wider towards the rear. It's been very hot & humid making it difficult to work outside Cross section of rocker/sill/B pillar reinforcement cut from a wreck Drilled out the sill welds on the spare section - I want to try & cut the inner repair piece from this Cut some sheet metal in preparation for bending Have to match the rocker section, and make some inner support sections Also put new handles on two sledge hammers I dug out of the yard many years back. Now I have 4 sizes - these two fall in the middle Edited July 12, 20241 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-667313 Share on other sites More sharing options...
July 12, 20241 yr comment_667319 2 hours ago, HusseinHolland said: Also put new handles on two sledge hammers I dug out of the yard many years back. Your place was a hammer farm back in the old days? Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-667319 Share on other sites More sharing options...
July 12, 20241 yr Author comment_667323 19 minutes ago, Captain Obvious said: Your place was a hammer farm back in the old days? I dunno - I also found a large amount of horseshoes, railroad tie nails and a pair of gas filing station 'guns' from the days before the vent caps were required. Not sure what all that was about. Link to comment https://www.classiczcars.com/forums/topic/68659-475-datsun-280z-leaf-green-ca-market-250k-miles-long-term-project-032023/?&page=17#findComment-667323 Share on other sites More sharing options...
