November 15, 20204 yr Author comment_610458 Thank you for your answers, and photos ! Helps me a lot 😉 I'm looking for them... Or to reproduce them. Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-610458 Share on other sites More sharing options...
November 16, 20204 yr Author comment_610519 Bonus question: on TheZstore shop, they offer 70-72 and 73-74 battery cables. Any idea of differences between them ? 😅 Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-610519 Share on other sites More sharing options...
November 16, 20204 yr comment_610532 Given the price, I’m kinda thinking they may be OEM cables. The Fiche does show different cables starting 72-07. Going to have to call them to get details if you want to see the difference I can imagine nothing location or lug size, or grounding difference. Might be a “better” battery terminal end upgrade or style or something Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-610532 Share on other sites More sharing options...
November 17, 20204 yr comment_610546 Hi All, I started following this thread when I got back from an extended work trip and thought this link might be helpful: https://www.240zrubberparts.com/apps/webstore/products/show/7319377 Although these may be too pricey for some, Steve Nixon reproduces the cables and they are perfect replicas. I suggest that instead of creating another replica, time and money might be better spent supporting the efforts of those that have already done it. In reference to a few of the questions above: The Z Store does not have any of these original cables in stock and it is highly unlikely they will ever have them again. I purchased some of the last ones they had several years ago and have found a couple of sets from a Canadian source since, but recent inquiry informs that they are now unavailable. There is no discernible difference in the 70-72/ 73-74 cables. I have them installed on my 73. CanTechZ is correct. The positive cable is the only one that had a terminal insulator cap originally. Steve's reproductions have them on both in an abundance of caution. (Many Z owners do not purchase batteries with the correct terminal orientations) zKars your photography skills are really getting better---great closeups Jim! Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-610546 Share on other sites More sharing options...
November 17, 20204 yr comment_610569 I really don’t want to get in the reproduction parts business, at least not yet. I do want to produce “reasonable” items that come close to the originals at first glance at a reasonable price for my own projects. I will include my rough notes and doodles of the detail measurements of my negative cable. Sorry for the not-perfectly readable scribbles. No I’m not a doctor. Edited November 17, 20204 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-610569 Share on other sites More sharing options...
November 17, 20204 yr comment_610571 Great reference material Jim! When I posted above I had not yet read your exchange with Rich (motorman7) regarding creating the cables using the Pep Boys type terminal ends. You guys continually amaze me in your inventiveness and adaptations using off the shelf pieces, getting very acceptable (reasonable) results. To Everyone: Please accept my apologies if my comments appeared to be disparaging of anyone chosing to make their own. That was not my intent. Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-610571 Share on other sites More sharing options...
4 hours ago4 hr comment_677771 I am in the process of refurbishing a pair of original battery terminal cables.After removing the terminal clamp bolt on the negative cable, I noted that bolt (6.0 mm x 1.00 mm x 1-1/4") had a rounded “U” head to match the profile of the terminal clamp.As you can see from the attached photos, there is no indication that the bolt head was modified with added metal to reshape a square or hex head bolt to form the rounded edge.Has anyone else seen a terminal clamp bolt with this rounded “U” head?Thanks,Keith Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-677771 Share on other sites More sharing options...
4 hours ago4 hr comment_677772 I’ve seen those bolts with the one flat side that keeps it from spinning when you tighten the nut. I remember having to wedge a flat head screw driver underneath to keep it from spinning. Edited 4 hours ago4 hr by Yarb Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-677772 Share on other sites More sharing options...
3 hours ago3 hr comment_677775 Keith I picked up a NOS 240Z battery cable off EBay and it has the rounded head. Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-677775 Share on other sites More sharing options...
2 hours ago2 hr comment_677776 21 minutes ago, SpeedRoo said:Keith I picked up a NOS 240Z battery cable off EBay and it has the rounded head.Great!Any suggestion on how to duplicate the bolt head?Thanks,Keith Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-677776 Share on other sites More sharing options...
2 hours ago2 hr comment_677782 20 minutes ago, zed2 said:Great!Any suggestion on how to duplicate the bolt head?Thanks,KeithKeith buy a battery bolt and round off two of the corners with a grinding wheel, https://www.amazon.com/Wilmar-W1680C-Battery-Terminal-Bolt/dp/B0076EVKO8 Link to comment https://www.classiczcars.com/forums/topic/64705-240z-factory-battery-cable/?&page=2#findComment-677782 Share on other sites More sharing options...
