May 10, 20214 yr Author comment_621389 it looks like my valve doesn't have a connector for the wire.  Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621389 Share on other sites More sharing options...
May 11, 20214 yr comment_621390 it looks like my valve doesn't have a connector for the wire.  That is your prop valve. The safety valve is under the MC on the driver side. Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621390 Share on other sites More sharing options...
May 11, 20214 yr Author comment_621392 I dont have that valve. I guess the previous owner removed it?  Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621392 Share on other sites More sharing options...
May 11, 20214 yr comment_621395 Should look like this without the additional prop valve. Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621395 Share on other sites More sharing options...
May 11, 20214 yr comment_621416 14 hours ago, grannyknot said: That one of your brake line circuits has a leak and now you are using the other circuit to do all the braking. If I remember right, the wire under the seat is the one that finally made the light go off so I'll plug the G/YÂ back and see what happens. Thanks Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621416 Share on other sites More sharing options...
May 11, 20214 yr Author comment_621417 I am assuming that it will still work if deleted but not be as safe, correct? Can anyone help with question 2 and 3 in the previous post  Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621417 Share on other sites More sharing options...
May 11, 20214 yr comment_621448 8 hours ago, gotham22 said: Can anyone help with question 2 and 3 in the previous post There are a few connectors in the wiring harnesses that I have seen that don't seem serve a purpose and nothing plugs into them. I can only assume that it was easier make up the wiring harnesses so they would work in many parts of the world although not all of the wiring was needed in every jurisdiction. Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621448 Share on other sites More sharing options...
May 12, 20214 yr Author comment_621495 makes sense, thanks grannyknot  Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-621495 Share on other sites More sharing options...
May 25, 20214 yr Author comment_622090 Well, I was able to start the engine which is a great thing....but now it sounds like this. Where do I start troubleshooting? IMG_3607.mp4 Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-622090 Share on other sites More sharing options...
May 25, 20214 yr Author comment_622092 Reading somewhere that this might be an exhaust leak. Is that possible. I do have some white smoke   Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-622092 Share on other sites More sharing options...
May 25, 20214 yr comment_622095 Sounds absolutely mechanical, not exhaust. I'd check oil pressure first. Don't rely on the gauge. Either plumb in a mechanical gauge or pull the valve cover and be sure there's plenty of oil being delivered topside. Then, do a valve adjustment. If everything's okay thus far and you still have that knocking, I'd start thing rod bearings. Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-622095 Share on other sites More sharing options...
May 25, 20214 yr comment_622103 I agree, that sounds like a clearance noise. Start with valve lash first Then record again Link to comment https://www.classiczcars.com/forums/topic/60184-rust-advice-78-280z/?&page=23#findComment-622103 Share on other sites More sharing options...
