Really cool project. Does the ports on your intake manifold match up with the intake ports on the head? Seems to me when I was at Eiji’s shop, the Jenveys needed work on my head to match the ports on the intake.
Jenvy’s should match right up to my SK intake.
2 minutes ago, madkaw said:
The wheel is for a crank sensor ,  Im not sure how it works for a cam sensor .
I get a little confused on all the signals and such.  But most crank sensors are 36-1 which tells the ecu it a lot of info but not enough to know if it's intake or exhaust. The 60-2 tells the ecu exactly what stroke its on.  So that is all it needs.  But again, I am a giant newbie on all of this.  So?
You have a link to this product - I can’t find it . I thought 60-2 wheel is just another version of a 36-1 wheel. I thought two separate sensors were needed or two separate wheels to run sequential
