May 2, 20196 yr comment_574739 Be careful. I see a socket lurking... Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574739 Share on other sites More sharing options...
May 2, 20196 yr Author comment_574745 it's probably a 10mm:) Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574745 Share on other sites More sharing options...
May 3, 20196 yr Author comment_574786 Nos 240z starter solenoid score. eBay 9$ shipped! Time to rebuild the starter. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574786 Share on other sites More sharing options...
May 3, 20196 yr comment_574790 On 4/29/2019 at 5:55 PM, duffymahoney said: More stuff back from zinc. Time to install some stuff. Man, that zinc plating looks great!! Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574790 Share on other sites More sharing options...
May 3, 20196 yr Author comment_574791 I wanted to send it back, since it was so blue/ purple, I decided to just live with it. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574791 Share on other sites More sharing options...
May 4, 20196 yr comment_574819 16 hours ago, duffymahoney said: I wanted to send it back, since it was so blue/ purple, I decided to just live with it. Did you contact them at all? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574819 Share on other sites More sharing options...
May 4, 20196 yr Author Popular Post comment_574835 Well shimming the r-180, backlash, pre load and wipe pattern took most of a couple days after work and most of a Saturday morning. I think I took it apart 20+ times. Finally happy with the wipe pattern. Luckily I didn’t have to change the pinion shim. Edit: I think in a perfect world I would have had a special tool to set the pinion nut at the factory 125-150ftlb. Then used different shims to get the bearing pre load perfect. But I had no way, so a couple of hits with the impact is what I used to set pre load, I found that info on here and a few youtube videos. It's not precise at all, just hopeful the factory had it correct enough. A bunch of site posts and a few guru told me to just reuse the pinion shim and move on. Everyone basically told me backlash is the most important. Ended up with 5 thousandths for backlash give or take and then ring side backlash shim if .05 and other side of .07. Total inch pounds is around 8-10 on the pinion. No carrier I had around 3 inch pounds for the pinion. This is worth paying someone to do. Just FYI. I had fun. But super frustrating. Edited May 5, 20196 yr by duffymahoney Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574835 Share on other sites More sharing options...
May 5, 20196 yr Author comment_574851 She is in. Gosh I hope it works nicely and I didn’t screw up! I really like how the half shafts hades turned out. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574851 Share on other sites More sharing options...
May 5, 20196 yr Author comment_574852 Osgiken clutch is in. Big thanks to Zgarage for the kit. Install was a breeze. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-574852 Share on other sites More sharing options...
May 15, 20195 yr Author comment_575462 I got the starter put back together. Hopefully it works! Sure looks nicer. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-575462 Share on other sites More sharing options...
May 15, 20195 yr Author comment_575463 Finally got the ka trans. This is a low mileage (500) miles trans. Been sitting on the shelf since 1989. I found it on some parts website. Vapor and some zinc and it’s looking amazing. Bell housing mods are being done Emerish racing. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-575463 Share on other sites More sharing options...
May 15, 20195 yr comment_575499 The bracing flanges on that case look amazing! Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=31#findComment-575499 Share on other sites More sharing options...
