1 hour ago, Jason240z said:
I watched the video?' i'm not sure if you said that was at the wheels or not?
The engine was in the car, not on a stand so that should give you a hint ?
6 minutes ago, 240260280 said:
I noticed the Dyno RPM on the screen seems off? Was the dyno working OK?
Are you talking about the road speed reading? The Dyno was all working well.
11 minutes ago, Home Built by Jeff said:
175kph. That dyno is strange though working in HP and ft/lbs as most here in Aus use KW and NM.
I was surprised to see it show HP.  Every other dyno run I have seen in Australia showed power in KW.
