May 15, 20178 yr comment_521022 The bottom ends on these cars are super durable. Worst case, it might need to have the head worked on, which can be done with the engine in the car. Moisture from the exhaust is normal. It's a byproduct of combustion. You'll need a Philips head screwdriver for the hose clamps, and a 10mm socket with an extension for the valve cover bolts. If you've rebuilt a mower engine, you can easily get the cover off and determine the source of the problem. Remove the hose, loosen the screws (leave them in the holes), and lift the cover straight up. It's designed for easy, often, removal. The gasket will probably tear when you remove the cover, so try to find a new one before you start. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521022 Share on other sites More sharing options...
May 15, 20178 yr comment_521027 If you can, take pics when you remove the cover. We all want to see what gremlin lurks under it. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521027 Share on other sites More sharing options...
May 16, 20178 yr comment_521077 Seriously just download a manual and get dirty and pull the engine if you do it by the steps it by the steps its not that bad and redo your ringsSent from my SM-G530W using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521077 Share on other sites More sharing options...
May 16, 20178 yr comment_521097 8 hours ago, D280z said: Seriously just download a manual and get dirty and pull the engine if you do it by the steps it by the steps its not that bad and redo your rings Sent from my SM-G530W using Classic Zcar Club mobile I'd pull the valve cover first and look for the gremlin. You could get a bore scope and take a look at the cylinders but most of the time they're fine. I'm still betting the tapping is coming from the valve train. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521097 Share on other sites More sharing options...
May 16, 20178 yr Author comment_521103 Thanks for all of the responses. I'm going to jump in and lift the valve cover. Since the engine was solid back in 03, and the tapping just started when I restarted it, I'm going to hope that is where the issue lies. With 0 compression in one cylinder and 50 percent in the another ill keep my fingers crossed its there. The original miles are about 87k so I'm hoping the rings are solid. I at least have hope that since It's body spent most of its life in so cal and solid that the engine is worth the work. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521103 Share on other sites More sharing options...
May 16, 20178 yr comment_521125 6 hours ago, Kirob24 said: the tapping just started when I restarted it, I'm going to hope that is where the issue lies. With 0 compression in one cylinder and 50 percent in the another ill keep my fingers crossed its there. Who measured the cylinder pressures that you referred to in Post #1? Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521125 Share on other sites More sharing options...
May 16, 20178 yr Author comment_521130 Mechanics at classic car shop. I'm beginning to wonder why they didn't lift the valve cover Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521130 Share on other sites More sharing options...
May 16, 20178 yr comment_521132 We all wondered that too. You don't $uppo$e they wanted to $ell you a new engine? Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521132 Share on other sites More sharing options...
May 17, 20178 yr comment_521142 Any "old engine" shop that saw those numbers would think bent or stuck valve first. Not engine rebuild. The shop didn't try to sell him anything though. They didn't want to work on it. Overall, you have to wonder if they really put much effort in to the pressure checks. A simple inspection, and a couple of measurements of your own and you'll be way better off, knowledge-wise, than you are now. You might be able to borrow a pressure tester at a parts store. Get the screw-in type. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521142 Share on other sites More sharing options...
May 17, 20178 yr comment_521143 A lot of tools like compression testers are available on a rental system from the chain parts stores... Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521143 Share on other sites More sharing options...
May 17, 20178 yr comment_521147 And if you get stuck, send me a PM and I might be able to swing by to lend a hand. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521147 Share on other sites More sharing options...
May 17, 20178 yr comment_521150 I've had a few Yuenglings n Pottstown. The fish in the river are these weird orange and gray hybrid Koi-Carp. My Irish buddy though they were fantastic trophy sport fish. Link to comment https://www.classiczcars.com/forums/topic/57728-engine-rebuild/?&page=2#findComment-521150 Share on other sites More sharing options...
