April 22, 20178 yr comment_518781 just so you know, when you first fire that up, the header wrap will smoke like a train. Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-518781 Share on other sites More sharing options...
April 23, 20178 yr comment_518859 Where's my sunglasses??? Found 'em. Ahhh. That's better. Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-518859 Share on other sites More sharing options...
May 24, 20178 yr Author comment_521625 Ok for those interested in this project. Did have a hardtime tuning the carbs. First there was a little peace of junk in the gas tube the hard part under the float bowl. This thing was acting like a butterfly but without control on it so sometimes the carb was ok and sometimes there was no or almost no gas going to the jet. It got obvious when at a moment it shut and stayed shut. After removing it I rebalanced everything And the carbs are running great now. Just need to change a choke cable that is not working properly. I would recommand Paltech Anytime. But you need to know how to adjust and debug carbs when you put them back in. This is not plug and play. Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-521625 Share on other sites More sharing options...
May 24, 20178 yr comment_521634 it should be plug and play... Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-521634 Share on other sites More sharing options...
May 24, 20178 yr comment_521645 5 hours ago, jeanp said: Ok for those interested in this project. Did have a hardtime tuning the carbs. First there was a little peace of junk in the gas tube the hard part under the float bowl. This thing was acting like a butterfly but without control on it so sometimes the carb was ok and sometimes there was no or almost no gas going to the jet. It got obvious when at a moment it shut and stayed shut. After removing it I rebalanced everything And the carbs are running great now. Just need to change a choke cable that is not working properly. I would recommand Paltech Anytime. But you need to know how to adjust and debug carbs when you put them back in. This is not plug and play. What was plugging? the bowl to jet fuel line? I can't imagine what it could have been. I thought the lines were new? Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-521645 Share on other sites More sharing options...
July 11, 20178 yr Author comment_525446 Lines where new there was a round flat peace of junk the size of the hole in the botom of the bowl. it was stuck in the hole the hard part of the bowl not in the line itself. it was sometime closing everything and sometime open. It may have come from the job i had done on my fuel rails. I had them powder coated last winter also. So i cannot say that paltech left this there or it traveled from the fuel rail. Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-525446 Share on other sites More sharing options...
July 11, 20178 yr Author comment_525447 For those interested, I did change my inner choke cables with .055 piano wire. like http://woodworkerb.com explain and it works realy good that is a realy cheap fix. So i am done with the carb project. everything work fine there. Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-525447 Share on other sites More sharing options...
July 11, 20178 yr comment_525488 I have only had one experience with Paltech, as he refurbished the DCOEs on my Roadster. Car would not run after very well. He had installed one of the venturis in backwards... They do look fantastic though. As my old DCOE's on my Z are getting older and 'wearing' in, I think they could use a bit of a tune up. I may try myself, but we will see. I do love playing with carbs. Have not done a total rebuild on one since my Holley 4150 days. Edited July 11, 20178 yr by Zedyone_kenobi Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-525488 Share on other sites More sharing options...
July 12, 20178 yr comment_525590 On 7/11/2017 at 7:44 AM, Zedyone_kenobi said: I have only had one experience with Paltech, as he refurbished the DCOEs on my Roadster. Car would not run after very well. He had installed one of the venturis in backwards... They do look fantastic though. As my old DCOE's on my Z are getting older and 'wearing' in, I think they could use a bit of a tune up. I may try myself, but we will see. I do love playing with carbs. Have not done a total rebuild on one since my Holley 4150 days. Thank you for those SUs by the way....they are about to finally go on a car. Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-525590 Share on other sites More sharing options...
July 12, 20178 yr comment_525597 Very happy to hear it I Hope they make you smile every single day! Link to comment https://www.classiczcars.com/forums/topic/56497-paltech-carb-rebuild/?&page=2#findComment-525597 Share on other sites More sharing options...
