November 4, 20204 yr Author comment_609577 1 hour ago, Patcon said: I knew they were long. I have 2 on hand, just didn't know how they compared. Would be interesting to see how the ld28 intake affected torque with the long runners I plan on finding out . If anything - it will look cool Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-609577 Share on other sites More sharing options...
November 4, 20204 yr comment_609580 Yes, yes it will! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-609580 Share on other sites More sharing options...
November 12, 20204 yr Author comment_610143 Dynoooooooo Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-610143 Share on other sites More sharing options...
November 12, 20204 yr comment_610182 Nice! Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-610182 Share on other sites More sharing options...
November 14, 20204 yr comment_610321 On 9/25/2020 at 7:22 AM, madkaw said: What’s your max ignition timing 100kpa 34 degrees. Nice results, a Z should be plenty fun with those numbers. 😉 Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-610321 Share on other sites More sharing options...
November 14, 20204 yr Author comment_610329 1 hour ago, LeonV said: 34 degrees. Nice results, a Z should be plenty fun with those numbers. 😉  Very fun. The run 226/226 was 38 degrees timing I believe . Normally I run 36 max . Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-610329 Share on other sites More sharing options...
November 16, 20204 yr comment_610529 Was that on 91 pump gas? I'm long overdue for another dyno session. I tuned mine with Weber jets but have since installed Keith's. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-610529 Share on other sites More sharing options...
November 17, 20204 yr Author comment_610538 2 hours ago, LeonV said: Was that on 91 pump gas? I'm long overdue for another dyno session. I tuned mine with Weber jets but have since installed Keith's. 93 Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-610538 Share on other sites More sharing options...
May 10, 20214 yr comment_621371 Awsome, great job. Link to comment https://www.classiczcars.com/forums/topic/51459-l28maxima47-build/?&page=24#findComment-621371 Share on other sites More sharing options...
