July 10, 20196 yr comment_579334 My buddy did that to his car above. The headlights still mount the same way as stock. He just welded the scoops on. No other changes required. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579334 Share on other sites More sharing options...
July 10, 20196 yr Author comment_579337 Should have just bought the fenders off of @zkars .... his we’re already done. Edited July 10, 20196 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579337 Share on other sites More sharing options...
July 10, 20196 yr comment_579345 Be sure and mount the hood before working on the buckets or fenders. Would hate to see you fix it and then have to redo it. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579345 Share on other sites More sharing options...
July 10, 20196 yr Author comment_579346 For sure. This was just a quick mount and check. I have to get the doors stripped still too. The hood looks pretty good with it just sitting on the car. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579346 Share on other sites More sharing options...
July 10, 20196 yr comment_579349 I just noticed, but no heat shield for the intake manifold? Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579349 Share on other sites More sharing options...
July 11, 20196 yr Author comment_579352 It’s in progress. I am modifying the lower shield to adapt to the throttle cable linkage Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579352 Share on other sites More sharing options...
July 11, 20196 yr Author comment_579359 This side is much better! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579359 Share on other sites More sharing options...
July 11, 20196 yr comment_579374 15 hours ago, Captain Obvious said: Now is a good time to just weld the sugar scoops on and be done with that gap altogether. That is how Matsuo Designed it. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579374 Share on other sites More sharing options...
July 11, 20196 yr comment_579377 I love the look. My guess is the only reason they made the headlight scoops a separate piece is they just couldn't form one sheet into the shape they wanted. Either geometrically impossible, or too much stretching for the metal to handle. I suspect if they could have successfully made the fender / scoop one piece, they would have. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579377 Share on other sites More sharing options...
July 16, 20196 yr Author comment_579711 More fun with doors. @zKars provided me with nice “looking” replacement doors for my beat up originals. The first one (passenger side) was a disappointment with a lot of bondo and mashed panel metal. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579711 Share on other sites More sharing options...
July 16, 20196 yr Author comment_579712 The original driver door was pretty bad too. Lots of welds and dents. Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579712 Share on other sites More sharing options...
July 16, 20196 yr Author comment_579713 The good news was that the replacement driver door from Jim was almost perfect! Link to comment https://www.classiczcars.com/forums/topic/50908-1976-280z-restoration-project/?&page=219#findComment-579713 Share on other sites More sharing options...
