Skip to content
Electronic ignition upgrade advice wanted
I'm not planning on putting the original distributor points and condenser system back on my 71 240Z.
A friend of mine is telling me to use a 123 ignition and an MSD6AL. Good or?
Years ago I installed electronic fireball ignition system on an old GMC truck that I still have. I've never once had a problem with that upgrade. I'd like to do the same thing with the Z.
Anyone have experience and advice to point me in the right direction. Thanks in advance for the group's help.
Restoration update as of 12-16-25.
EDIT: Your work looks fantastic! I run a 280 radiator with a full ZX shroud on mine. 173F at idle sitting in my garage without any air flowing into the front.
Here's the two that helped me the most on my ZX swap. It works great with my Fireball PS20 coil. Bought the dizzy and coil from amazon.com
If you'll read Mr Moore's 1st post down at the bottom he's created an Excel spreadsheet with all the different values. I chose the 1979 and was lucky enough to get one back in 2015 I think. You'll need the ZX base. Maybe Junkyard Jenny would have one? I was lucky enough to find one at a local junkyard. The atlanticz.ca thread shows the installation on a 280 but there's a wiring diagram on there too for the 240Z. I can't really remember but I think I run 17 degrees at idle and 34 at 3,000 RPM. Sorry for my poor memory, too many motorcycle wrecks involving my head. 😁
https://atlanticz.ca/zclub/techtips/distributor/index.html
Edited by siteunseen
Do you want something that looks "factory" or time period correct or just something functional? With the 123 you don't really need the MSD unless you want the multi-spark.
I would beware of the old names. Many have been sold to conglomerates that source the manufacturing to low cost overseas factories.
If it was me I'd look for a system that has readily available replacement modules. Some of the old name brands are expensive to fix if the modules fail.
Something that is functional easy to install and gives me zero trouble for the next 20 years.
I’m not too concerned about looking fancy or. correct. I just want something that’s trouble free once I’ve gone through the steps to install. It. Don’t wanna have to go backwards and fuss with it later.
I’m out working on the car now. I’ll have more time to research when I get back in my office this evening.
Thanks to all the input I’ve received.
I did a quick shoparound and can't find the E12-80 module, for the ZX distributors, for sale anywhere, new. Only eBay used is out there.
I did run across a Mallory Unilite module for $83 on Summit.
Pertronix conversions are still out there. You could use one of those to trigger an MSD6AL or a GM HEI module. The Pertronix module should last longer since it won't see the coil current. Or it might be fine as-is.
The 123 looks nice in that it seems to have current limiting in the module so you can get a higher energy spark, and the advance curves are tunable. One problem with old used distributors is you get the advance curves that they came with usually, unless you can dig up other weights or vacuum advance canisters.
Fun problem to have. Good luck.
https://123ignition.com/product/tuneplus-6-r-v-datsun/
123ignition is proud to announce the first fully programmable Bluetooth ignition! Control your 123\TUNE+ with your iOS/Android smartphone or tablet. The App makes it possible to adjust the ignition curve and shows an electronic dashboard.
Main features: REV-counter, Antitheft system by a PIN code, Real time tuning, Vacuum advance, Boost retard, Soft REV-limiter, etc.
Cylinders
6
Model
Tune+
Operating voltage
4-15V
Positive earth supported
Yes
Wires
Black: coil '-'
Blue: battery negative
Red: ignition key (battery 6V / 12V)
Vacuum
Yes
Rotation direction
CW & CCW
IE (D-jetronic support)
No
RPM range
500-10.000 RPM
Brand
Datsun
Environmental temperature
-30 – 100 °C
Cap type
Straight
Dwell
Constant current: fully automatic adaptive dwell
Coil charging time-out
After 1 second, coil current is turned off
Spark balancing
<0.5 degrees
Maximum advance
40 degrees crankshaft
Forgot to say that you can wire up a GM HEI module to both the Z and ZX electronic distributors.
Oops, I looked for 1982 which uses the E12-92 module ( not available) and searched E12-80 on the internet. Thanks for checking.
The Rockauto E12-80's look like they came from the same mold. Two choices. $42 or 126.
Anyway, lots of good information not sure I have a final simple answer on which system to go with at the moment. The car is being restored pretty much bone stock except for larger intake and exhaust valves from a 280Z in the cylinder head.
So. race, fancy, adjustable is probably not something that would be much of a value to me as I'm looking for a simple plug and play conversion. Much like the fireball unit I put in my 1956 GMC truck 30 plus years ago.
My neighbor across the street recommended Pertronix 91761 igniter II Hitachi. Any thoughts on going that direction?
Thanks guys
What is the condition of your distributor bushings? Meaning is there any wobble/back and forth movement when you move the shaft? If so you might want to go with a new system. IMO
