Skip to content
Molded Seat Foam Insert Kit
I purchased a seat foam kit for my 1972 240z awhile back and find it to be too stiff. Has anyone trimmed the foam to make it more comfortable and plush. I was thinking of taking about removing about 1 in from the seating area so that you will sit down in the seat more. What techniques have been used to trim this foam.
Seat cover fit might suffer. In essence, you'll be increasing the height of the side bolsters by 1 inch. The centre panel of the seat cover would end hanging in space above the carved-out foam. Occupant weight will force the cover down onto the foam, but the look (baggy) when the seat is unoccupied might make you wish you'd never tried it. I suggest that you run the idea by an experienced auto upholstery pro before you break out the carving knife
Dou you have any spacers in the mounting hardware that can be swapped to the bottom side of the seat mount?
Here's something to read through. This guy is something else, he don't know half arse hence the name Hardway.
The kit I purchased was from Motorsports Auto. I had to remove all of the spacers so my head did not hit the roof. As mentioned, I want to contour the seat foam so I sit down in the foam and not on top of it. The foam is very stiff and does not conform to your body. Looking for suggestions as best method to contour for foam.
I was thinking on buying that msa kit but now you are mentioning a problem with the molded seat!
I swapped the seats in my 12/70 car for some seats I scored from a 77 280Z. I did the new foam from MSA and also did leather from Interior Innovation. The big reason was so I could have the extended tilt forward and back like I had in my 73 240Z. This makes access to the tools which are on the floor behind the seats in the early cars before they did the tool bins in the rear deck floor. When I was done I did find that I sat maybe an inch or so higher but I'm now used to it and I can see a little further down the hood. I'm only about 5'9" so I have no issue with my head clearance to the roof. Bottom line is I'm pleased with the swap and would do it again.
Automotive upholster...
I think the best tool for cutting foam is a hotwire cutter but that isn't for the faint of heart.
I've seen people use an electric knife for cutting foam. I've not tried it, but it looked like it worked well.
Clean the turkey off and cut the seats up. I used one on my boat seats years ago.
