Skip to content
The time has come for Zedyone to really look at brakes.
On 11/22/2025 at 11:58 AM, conedodger said:
Ok, cancel the Yarbinator. I found a video on YouTube and it only takes three wires.
Frankly, the video is one of the best produced car vids I’ve ever seen on YT. If I knew how to link it…
To share a YT video, there should be buttons underneath it, one of those being share.
Click on the Share button, click on the Copy button, and paste the link in a post here.
If it's an embedded video, right click on it, and choose Copy video URL
I'm not sure what is causing the confusion with the wiring. It seems straightforward to me.
I said to take the power for Pin 1 from the alternator so if your Z has an ammeter, it doesn't indicate a drain when the booster is boosting. The black/white wire should be the one that goes to the ballast resistor (pre 78).
Am I missing something?
Edited by SteveJ
3 minutes ago, Yarb said:
@SteveJ Are you suggesting the sensor connections aren’t needed because abs etc is not a factor?
The other connections are just as listed in the drawing.
The other 19 pins in the big connector are left blank.
Connector kit: https://www.ebay.com/itm/267047224965?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOooPV5nflCm9OG4z_qtvTPN_DJ6ObmXrBJVU3X80I3uMTYxV2QYHG0Y
Edited by SteveJ
I wonder. Do we need the Bosch brake pedal as well? I’m inclined to do this if it doesn’t require the pedal modification as well…
Steve, I don’t think there is any confusion on the wiring. I was teasing my brother Yarb…
If the clevis pin lines up with the pedal, you're good to go. If you're truly curious about this conversion, look on ebay for Honda electric brake boosters. You won't have to worry about the angle on the MC reservoir.
Just now, SteveJ said:
Here's someone adapting the iBooster to a Z32.
Either he's making it harder than it should be, or this is not a conversion for the faint of heart.
In its native installation, it can be more complex. I think the brake pedal has position sensors. Not sure if that is a safety thing. It could be redundant feedback. Similar to drive by wire with sensors to measure gas pedal position and throttle position.
Go down to the "Push Rod Considerations" section of this link: https://www.evcreate.com/installing-the-ibooster/
