On 11/22/2025 at 11:58 AM, conedodger said:
Ok, cancel the Yarbinator. I found a video on YouTube and it only takes three wires.
Frankly, the video is one of the best produced car vids I’ve ever seen on YT. If I knew how to link it…
To share a YT video, there should be buttons underneath it, one of those being share.
Click on the Share button, click on the Copy button, and paste the link in a post here.
If it's an embedded video, right click on it, and choose Copy video URL
I'm not sure what is causing the confusion with the wiring. It seems straightforward to me.
I said to take the power for Pin 1 from the alternator so if your Z has an ammeter, it doesn't indicate a drain when the booster is boosting. The black/white wire should be the one that goes to the ballast resistor (pre 78).
Am I missing something?
Edited by SteveJ
3 minutes ago, Yarb said:
@SteveJ Are you suggesting the sensor connections aren’t needed because abs etc is not a factor?
The other connections are just as listed in the drawing.
The other 19 pins in the big connector are left blank.
Connector kit: https://www.ebay.com/itm/267047224965?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOooPV5nflCm9OG4z_qtvTPN_DJ6ObmXrBJVU3X80I3uMTYxV2QYHG0Y
Edited by SteveJ
Steve, I don’t think there is any confusion on the wiring. I was teasing my brother Yarb…
