Has anyone ever rebuilt or otherwise repaired the floor vents on their S30, the ones operated by the pull knobs under the dashboard?
I'm starting to reattach all my interior bits and pieces, I noted that after only 54 years, the "rubber" that seals the vents closed has cracked and broken off in a few places which is plainly evident in the photo. That will make for some drafty driving in cool weather.
I estimate the material thickness at about 1 mm (1/25" or 0.040"). I see 0.040", 60A durometer, adhesive-backed, transparent silicone rubber sheeting (about 1/2 square foot) on Amazon for $11 so that's my target material at the moment as the silicone should never "dry out" and get brittle. Anyone have an alternative?
Also, the movable flap looks to be held in place by and pivots on two pins that protrude into the air horn and look to be retained by plastic, friction-fit washers. Has anyone disassembled one of these and determined if everything survives the process to then get reassembled?
Edited by Seppi72
correcting typo
https://www.classiczcars.com/forums/topic/69565-floor-vent-rebuild/
I redid that foam on mine but decided disassembly was a bad idea. I bought some thin foam off amazon. Glued it on an closed the flap to hold it. Trimmed to fit after it cured
Here is a post showing a bit about what I did to redo mine: https://www.classiczcars.com/forums/topic/63087-restoration-of-bringatrailer-240z-hls30-35883/page/63/?&_rid=2858#findComment-663237.
I can't find it now, but someone found a material that I thought may be a better choice. It may have been @Patcon. The rubber I used is very durable, but it is rubber sheet. I found it to be less "shapeable" than the original foam like material. If I had to do it again, I'd look for a very thin neoprene or more foam like material, as I think this material would folder around the edges of the flap better.
Thanks for your reply, inline6. Here is that portion of your build thread. Excellent pix. Very helpful. I'll check out Grainger, McMaster-Carr and others for thin neoprene foam.
As and aside, I tried searching just the "S30 Interior" portion of the forums for this specific topic before posting this new thread, but "vent" returns over 500 hits and I didn't want to spend the time investigating each one's summary to see if it was germane. I know, I'm just plain lazy. But I remember spending countless hours in the departmental library "stacks" tracking down references in Chemical Abstracts back in the pre-computer days. Probably added 6 months to my graduate degree program doing that.
March 19, 2024
comment_663237
This past weekend, I rebuilt the side vents - the ones that are opened/closed via the knob underneath either side of the dashboard.  The rubber parts that seal around the edges of the disc that moves to close/open were dry rotted, but intact.  I thought about installing them as they were, but when I poked at the rubber, it crumbled easily.  These vent mechanisms are actually pretty difficult to remove/install, so I decided to rebuild them.  I have some thin rubber sheet I got from McMaster-Carr some time ago.  It comes in handy for making gaskets, and applications like these.
For each vent, I had to first remove all the old rubber material.  Then, I cut two semi-circular pieces a little over size so that the edge would fold over seal against the ID of the housing.  I then used the contact adhesive I have been using to glue them into place, one on one side, and one on the other.  To finish up, I cut some 1/8" this open cell foam which seals the vent housing to the car body.
Adhesive type matters. I have found contact adhesive available at local stores isn't good enough for high heat (automotive) applications. With interior temperatures going well north of 100 degrees repeatedly, it let's go.
This stuff does not. It is only available by the gallon, and has a relatively short shelf life (a year or so), but I find it to be amazing, and crucial for any adhesive application in our cars.
Edited by inline6
I agree. I bought a couple of pints of the regular stuff when I first started my upholstery work and quickly went through those (brushed everything on, no spraying) so I bought a gallon of the HHR and will likely have half of that leftover when finished with everything. Maybe I should rebuild another Z just to use it up? Oh wait, I have one of those...
Edited by Seppi72
added details
I replaced a headliner in a Toyota a few years ago and passed on the Weldwood Contact Adhesive because of the price and quantity. I used 3M Headliner and Fabric Adhesive. It comes in a spray can and was easier (more forgiving) to use than contact adhesive. The 3M has held up well, and I'd definitely use it again.
Thanks for your input, Mark. I installed the headliner first using some spray can adhesive I'd bought some time ago, probably from Motorsport Auto. All went well with the installation and I was patting myself on the back about it. Then, two days later the headliner was sagging in the middle. Figuring the solvent just needed time to evaporate and escape, I tried pressing it into place using coroplast pieces (coroplast is the stuff used to make most yard signs these days) wedged in place with appropriate lengths of scrap 2x4 lumber. After a week the headliner still sagged so I had to remove it, use xylene (a.k.a. xylol) to remove the spray can goop from the metal and that's when I went to brushing on the Weldwood HHR. No further problems.
You guys probably know this but if you're trying to restick an original headliner often the foam backing is so degraded that it fails internally, not at the surface.
Just posting for anybody who ends up like I did. I used 3M contact adhesive in a spray can. But the foam was "toasted" (literally) and it sagged again. I never did scrape off the old foam and try again. What I should have done.
Mine was clearly an adhesive failure and not a cohesive one. I suspect folks who have cars that have been out in the summer sun for many years might have the cohesive failure you experienced.
I removed the degraded foam before using the 3M Headliner and Fabric Adhesive. That was at least three years ago. The car has sat out in the weather year-round and still no sagging.
