Posted 15 hours ago15 hr comment_677409 My brake pedal felt lower and spoongy than normal when driving. Checked master cylinder reservoir and found it to be down in brake fluid about half way. I refilled it and checked all 4 wheel cylinders and brake lines under the car and all were dry. Test drove car again and pedal was still lower and spoongy. Is it possible that master cylinder is leaking back into the vac. booster? Or is my booster going bad? Or could both be happening. Vac. boosters are hard to come by for my 79zx. Any thoughts? Link to comment https://www.classiczcars.com/forums/topic/69468-79-280z-brake-problem/ Share on other sites More sharing options...
11 hours ago11 hr comment_677414 4 hours ago, mayolives said:Is it possible that master cylinder is leaking back into the vac. booster?This is possible. Unbolt the MC from the booster and pull it forward a bit. Fluid will leak out if the rear seal of the MC is leaking.If you do find a leak you might be able to save the booster if you clean out the brake fluid from inside. Not sure what the best way to do that would be. Maybe water, since brake fluid and water are compatible. Link to comment https://www.classiczcars.com/forums/topic/69468-79-280z-brake-problem/#findComment-677414 Share on other sites More sharing options...
8 hours ago8 hr Author comment_677416 Thank you Zed Head. I'll give it a shot. Link to comment https://www.classiczcars.com/forums/topic/69468-79-280z-brake-problem/#findComment-677416 Share on other sites More sharing options...
3 hours ago3 hr comment_677417 That’s good advice but you didn’t warn him about the disc dropping to the bottom of the booster. Link to comment https://www.classiczcars.com/forums/topic/69468-79-280z-brake-problem/#findComment-677417 Share on other sites More sharing options...
3 hours ago3 hr comment_677418 @mayolives do yourself a huge favor and research the disc I’m talking about located on the the end of the pushrod inside the booster. There are rebuilders for that booster. Edited 3 hours ago3 hr by Yarb Link to comment https://www.classiczcars.com/forums/topic/69468-79-280z-brake-problem/#findComment-677418 Share on other sites More sharing options...
