I have a slight leak at where the speedometer cable connects to the transmission. I ordered some seals but I'm unable to remove the pinion to install them. I removed the metal tab that holds it in place and can twist it with a lot of effort with a pair of channel locks (without damaging the threads) but only in one direction and it does not move out. I looked at this video but it wasn't too helpful:
Can anyone offer a suggestion? Maybe thread something onto the threads and use a slide hammer or something to tap it out?
https://www.classiczcars.com/forums/topic/69455-speedometer-pinion-stuck/
Slide hammer is not a bad idea, but good look finding that thread pitch.
I have vague memories of using a rag and a pair of vise-grips, with a hammer tapping sideways on the pliers. Or maybe a big screwdrive levering on it.
Anyway they do get stuck. Nothing special in there.
I found a new Z store.
TotalZParts
No image preview
Datsun 240Z 260Z 280Z 280ZX 300ZX Speedometer Pinion Gear...
NOS (new old stock) speedometer pinion gear full assembly, including the sleeve, seals, and the retaining pin. It has a 17-teeth gear & measures about 3 1/16" in total length. 18, 19, & 20 teeth ge...
Thanks for the suggestions. I'm worried about damaging the speedometer cable by pulling on its. I'll give it a try.
I might try and find an old speedometer cable and improvise a pulling tool.
9 minutes ago, Yarb said:
Your prying on the captive nut not the cable.
You will probably bee surprised how it pops out. I’ve removed quite a few. There’s also a seal inside the cog shaft that prevents oil going into the cable. The ring and seal are still available.
Edited by Yarb
There's also a keyway cut into the body. It was exposed once you took out the retaining bolt and the piece of metal that holds it in place. If you have a non-ZX transmission it sucks that it's on the top but you said you could turn it. It is a place that you could try prying...
Honestly, I've never seen one stuck that bad - and we've seen a lot of transmissions over the years - even series one monkey shifters.
