March 23Mar 23 comment_675393 Probably just quantity. Air can be pressurized too. The FPR can't tell the difference. Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675393 Share on other sites More sharing options...
March 23Mar 23 Author comment_675394 3 minutes ago, Zed Head said:Probably just quantity. Air can be pressurized too. The FPR can't tell the difference.Gotcha, that might be why we were getting standard fuel pressure when we had the gauge on, but still had to performance? Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675394 Share on other sites More sharing options...
March 23Mar 23 comment_675395 Maybe the crap in the tank is too large to pass through the filter screen in the tank. It just blocks it up instead Edited March 23Mar 23 by Patcon Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675395 Share on other sites More sharing options...
March 23Mar 23 comment_675396 S30.World. For a new tank and remove that variable. The only reason I am suggesting this is I had mine cleaned twice and the same results occurred until I put a new tank in.IMHO Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675396 Share on other sites More sharing options...
March 24Mar 24 Author comment_675404 2 hours ago, Yarb said:S30.World. For a new tank and remove that variable. The only reason I am suggesting this is I had mine cleaned twice and the same results occurred until I put a new tank in.IMHOGotcha - that's odd and a bummer Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675404 Share on other sites More sharing options...
March 24Mar 24 Author comment_675405 Would throwing a bottle of that Lucas cleaner every time I fill up do anything to break this stuff down, or is the consensus just 'keep the tank topped off'? Edited March 24Mar 24 by chaseincats Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675405 Share on other sites More sharing options...
March 24Mar 24 comment_675407 I would "vacuum " that out with an electric fuel pump. Then analyze what you take out for a diagnosis... Link to comment https://www.classiczcars.com/forums/topic/69303-low-powerlean-when-fuel-is-low/?&page=2#findComment-675407 Share on other sites More sharing options...
