10 minutes ago, gotham22 said:
Forgive me if this is an obvious question but how could I see it when driving. I want to see what happens when I press the gas quickly.
The redneck way is to use a long piece of hose. I took a different direction. I went a 0-30 from this brand: https://www.glowshiftdirect.com/elite-10-color-100-psi-fuel-pressure-gauge/
If you want a cheaper alternative: (Wrong part removed) https://www.ebay.com/itm/176895594944?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3D5a579eb1d3964f638fde15fc3eb8a2e0%26pid%3D101224%26rk%3D4%26rkt%3D5%26sd%3D176367258697%26itm%3D176895594944%26pmt%3D1%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall&_trksid=p2332490.c101224.m-1
I can't vouch for the quality, though.
Edited by SteveJ
The Good 'ol Boy way as was told to me by Fastwoman. Cost maybe $10? Don't drive around busy streets while watching the gauge, find a nice backroad and there won't be any issues.
I just semi-permanently installed the electric fuel pressure gauge in my car. My job (and helping the parts cannon crowd) has conditioned me to have more diagnostic info readily available.
Seems unlikely that the engine would use so much fuel when accelerating that fuel pressure would drop. Probably learn what you need to know just blipping the throttle by hand with the hood open.
You could connect to the cold start valve hose. It's basically "on the rail" and sees what the injectors see. Don't forget to block the hole in the manifold. Never mind, no need to remove the valve. Just the hose. Good luck.
Edited by Zed Head
I connected a fuel pressure tester between the fuel filter and the fuel rail. At idle, the pressure reads 32 psi. When I manually move the throttle, it increases to about 38 psi. However, I’m unable to replicate the issue while the car is parked — I can’t drive it out of the garage right now to test it under load. Given that I can’t reproduce the issue when not driving could this point to something other than fuel pressure. My first thought before all of this was that it was a transmission issue. But I took it to a transmission guy who said everything was fine.
I don’t think there is a correlation just letting everyone know I checked the transmission and then I moved on to the fuel pressure. I am just confused that I can not recreate the issue when not driving
