May 6May 6 Author comment_676047 Forgive me if this is an obvious question but how could I see it when driving. I want to see what happens when I press the gas quickly. Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676047 Share on other sites More sharing options...
May 6May 6 comment_676048 10 minutes ago, gotham22 said:Forgive me if this is an obvious question but how could I see it when driving. I want to see what happens when I press the gas quickly.The redneck way is to use a long piece of hose. I took a different direction. I went a 0-30 from this brand: https://www.glowshiftdirect.com/elite-10-color-100-psi-fuel-pressure-gauge/If you want a cheaper alternative: (Wrong part removed) https://www.ebay.com/itm/176895594944?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3D5a579eb1d3964f638fde15fc3eb8a2e0%26pid%3D101224%26rk%3D4%26rkt%3D5%26sd%3D176367258697%26itm%3D176895594944%26pmt%3D1%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall&_trksid=p2332490.c101224.m-1I can't vouch for the quality, though. Edited May 6May 6 by SteveJ Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676048 Share on other sites More sharing options...
May 6May 6 comment_676053 The Good 'ol Boy way as was told to me by Fastwoman. Cost maybe $10? Don't drive around busy streets while watching the gauge, find a nice backroad and there won't be any issues. Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676053 Share on other sites More sharing options...
May 6May 6 comment_676056 49 minutes ago, siteunseen said:The Good 'ol Boy way as was told to me by Fastwoman. Cost maybe $10? Don't drive around busy streets while watching the gauge, find a nice backroad and there won't be any issues.I just semi-permanently installed the electric fuel pressure gauge in my car. My job (and helping the parts cannon crowd) has conditioned me to have more diagnostic info readily available. Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676056 Share on other sites More sharing options...
May 6May 6 Author comment_676060 I purchased this a few days ago. I'll start thereBETOOLL 0-140PSI Fuel Injector Injection Pump Pressure Tester Gauge Kit Car Tools (Master) Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676060 Share on other sites More sharing options...
May 6May 6 comment_676061 Seems unlikely that the engine would use so much fuel when accelerating that fuel pressure would drop. Probably learn what you need to know just blipping the throttle by hand with the hood open.You could connect to the cold start valve hose. It's basically "on the rail" and sees what the injectors see. Don't forget to block the hole in the manifold. Never mind, no need to remove the valve. Just the hose. Good luck. Edited May 6May 6 by Zed Head Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676061 Share on other sites More sharing options...
May 6May 6 comment_676064 Hooking up a vacuum gauge is somthing else that helps find problem. You can get them at chain stores with loaner programs for free. Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676064 Share on other sites More sharing options...
May 11May 11 Author comment_676117 I connected a fuel pressure tester between the fuel filter and the fuel rail. At idle, the pressure reads 32 psi. When I manually move the throttle, it increases to about 38 psi. However, I’m unable to replicate the issue while the car is parked — I can’t drive it out of the garage right now to test it under load. Given that I can’t reproduce the issue when not driving could this point to something other than fuel pressure. My first thought before all of this was that it was a transmission issue. But I took it to a transmission guy who said everything was fine. Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676117 Share on other sites More sharing options...
May 11May 11 comment_676118 Not sure of the correlation between your transmission and fuel pressure for what you’re experiencing Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676118 Share on other sites More sharing options...
May 11May 11 Author comment_676119 I don’t think there is a correlation just letting everyone know I checked the transmission and then I moved on to the fuel pressure. I am just confused that I can not recreate the issue when not driving Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676119 Share on other sites More sharing options...
May 11May 11 comment_676121 There is no load on the engine Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676121 Share on other sites More sharing options...
May 11May 11 Author comment_676123 Could it still be a pressure issue when there is a load on the engine? Link to comment https://www.classiczcars.com/forums/topic/69175-loss-of-acceleration-when-hitting-gas-hard/?&page=2#findComment-676123 Share on other sites More sharing options...
