I have Fel pro on my 280. They were in the rebuild gasket kit at a local chain store. Working fine since 2011.
Nissan on my 240, also great since 2016.
Next question how do you recommend I flush the rust out of the channels. I can’t pull the car out side to use a hose and I don’t think it’s a good idea to use water with the pistons open right?
You should have done it before opening, but you can do it after you close it.. head on and clean the waterways.. I never had a clogged up engine but maybe someone here can say what to use besides lots of water..
20 hours ago, Zed Head said:
Air conditioning magnet valves (solenoids) and vacuum reservoir.  Take care of those parts, and the hoses.
How do I take off the electrical connectors? I don’t want to break anything 😅
I'm not sure but I think that you just peel the rubber boot back and pull them straight apart.  That's how other connections are up there.  Here's a thread with a picture of a set unplugged.
This worked! I didn’t peel the rubber back due to how brittle it was sprayed it with a little silicone before pulling
This is how I’m flushing the engine out.. hoa says I can’t do anything outside.
so I got tarps and taped it so water drains out of my garage. Plugged all the holes and I’m using an air compressor to flush the system with water. I had put vinegar into the the system for a few days before doing this.
look at all the hard Sediment that came out!
I will repeat until I see no more color in the water then I’ll remove the expansion plugs and do a visual check and flush
caution dirty water will go everywhere.
For the pistons I put on blaster and a towel but I don’t see any other way around it.
if any one has any ideas to help keep piston rings clean I’m all for it
