I've been looking for a good gasket to use with MSA header (round exhaust port). Not so sure about the MSA gasket that was included. After searching  I came across this https://www.ebay.com/p/Engine-Block-Cover-Gasket-ITM-09-50527-fits-76-78-Nissan-280Z-2-8L-L6/74968871?iid=302786175086
and was wondering if anyone has used one. I like the metal around the exhaust port. I know a lot of people recommend Datsun OEM but it does not have the round exhaust port. Appreciate the input.
MSA does a fair job of matching their parts.  Not sure why you'd want to second-guess them.  Is their a part number on their gasket?
If the metal ring lands in the gap between the exhaust liner and the head then it won't do much.  You do have an N47 head right?  The specs on the page you posted say 75-78 which covers square port and round.  Something seems off.
I've read on this and other forums that MSA's gasket seems to fail more often so I was looking for an OEM with round exhaust ports but everything I found had square ports.  I have a 77 with a P-79 head. I'll check and see if there is a part # on the MSA gasket.
The one you show Cliff is one I bought for my current 77 280 a few years ago. When I thought I was going to pull my head which I still have not done.
I mean intake :facepalm:
Edited by rcb280z
I meant intake, not head
