July 10, 20223 yr Author comment_642272 I’ll have a mechanic friend take a look this upcoming weekend.  we will be putting together the engine, trans, and clutch and installing on the 16th.  what radiators do y’all recommend? Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642272 Share on other sites More sharing options...
July 17, 20223 yr Author comment_642522 The rebello has been moved from Dad’s house to my house for prep to be dropped in.  currently working on mating the transmission to the engine. More fun to be had. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642522 Share on other sites More sharing options...
July 23, 20223 yr Author comment_642817 A lot of advice the past few days. Had the flywheel and clutch installed…. Then realized they may be different sizes. figured or they are both 225mm.  Then I realized I didn’t swap out the pilot bushing. Everything came off and had that fixed. Thanks to autozone for having a puller for rent. moved into the the transmission. Replaced the throw out bearing and reinstalled the fork and bearing.  I’ve heard the flywheel and pressure plate doesn’t need to be balanced because the L28 is internally balanced? What’s the verdict? Edited July 23, 20223 yr by MM569457 Wrong pic Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642817 Share on other sites More sharing options...
July 24, 20223 yr comment_642819 I saw your other post, wherever it is, about the pressure plate fit. Had a vague memory of a past thread about it, it's out there somewhere. Just now remembered the details. What I recall is that you can bolt a 240mm pressure plate to a 225 mm flywheel, using just 6 holes of the 9. If you use a 225mm clutch disc you should get 225mm performance but the outer edges of the pressure plate will not contact the disc. It will be like a 225mm clutch. Or you could use a 240mm disc but it would be riding on unsurfaced 225mm flywheel. Not clear what parts you ended up using or if you measured the parts. If I recall your other post, and from the pictures here, you have bolted a 240mm pressure plate to a 225mm flyhweel. Disc size unknown. Anyway...why did you grease the flywheel bolt holes in the crankshaft end? That's bad. You want them clean, and maybe even with some thread locker. Probably okay if you torqued them to spec but not really recommended. As far as balancing, you'll find guys that balance everything as an assembly, because they can and have made race engines. For insurance. But the parts are designed to be mix and match. Everything is balanced separately. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642819 Share on other sites More sharing options...
July 24, 20223 yr Author comment_642820 I wasn’t greasing the bolt holes, I was trying to get the pilot bearing out by packing grease. it was a mess… I cleaned the grease out. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642820 Share on other sites More sharing options...
July 24, 20223 yr comment_642821 Did you measure the stack height of the throwout bearing sleeve on the pressure plate? 92mm +/- a couple. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642821 Share on other sites More sharing options...
July 24, 20223 yr Author comment_642822 1 minute ago, Zed Head said: Did you measure the stack height of the throwout bearing sleeve on the pressure plate? 92mm +/- a couple. No I haven’t. I’ll get that knocked out Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642822 Share on other sites More sharing options...
July 24, 20223 yr comment_642824 40 minutes ago, MM569457 said: I wasn’t greasing the bolt holes, I was trying to get the pilot bearing out by packing grease. it was a mess… I cleaned the grease out.  Next time get a bolt slightly smaller than the bushing id and stuff the hole with bread. Hit the bolt with a hammer and add more bread. Repeat the process until the bushing (or bearing) slides out. It really works well and clean-up is a breeze. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-642824 Share on other sites More sharing options...
January 22, 20232 yr Author Popular Post comment_649566 Done. Engine and trans installed. Several trips to the auto store later. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-649566 Share on other sites More sharing options...
January 22, 20232 yr Author comment_649576 A little more background to the install. Our cherry picker wasn’t long enough to place the engine and transmission in connected, so we had to remove them separately.  Aftermarket motor mounts I purchased were Fowled up (paint/plastic were inside the bolt holes) and we had to tap and die M8x1.25 to clean them out. Had to fight the alignment getting the motor mounted for a bit. mounted the transmission from under the car. All in all a day effort.  Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-649576 Share on other sites More sharing options...
January 28, 20232 yr Author comment_649780 Radiator installed, but the OEM fan shroud doesn’t fit perfectly and leaves some gaps….  is this a big issue or would I need one that is flush? Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-649780 Share on other sites More sharing options...
January 28, 20232 yr comment_649786 It's probably like having half of a shroud. You won't know if it's a problem until you're sitting in traffic on a hot Texas day. But you'll have a possible improvement to add if it does overheat. Link to comment https://www.classiczcars.com/forums/topic/60341-resurrecting-a-1977-280z/?&page=13#findComment-649786 Share on other sites More sharing options...
