Skip to content
New Fujitsubo Exhaust System to be Released
3 hours ago, Jason240z said:
Did you not get the instructions books/manual etc from your supplier?
No instructions.  Anyone else get the kit?
I think this is what you should get
Thanks! That helps. I have the brackets backwards.
Do you have the system?
Install is going pretty smoothly. Guessing on mounts and directions of mounts. But I think I have it. I won’t tighten anything until the header is in. The header is at the ceramic coating shop. Hopefully finishing this weekend.
 Looks great!
Did you trial fit the header? I’m trying to find out whether the Fujitsubo one has the same fit issue around the steering as the Spirit Garage header and don’t see it in this thread.
Or is the header unchanged?
5 hours ago, Matthew Abate said:
 Looks great!
I get the header back probably wed from cermanic coating.  Then install time!:) Should clear and have around 2" from the steering shaft.
New Fujitsubo header is in! Well mostly. It’s coated in chromex ceramic coating inside and out for heat reduction.
Clears steering well. Also my series 1 heat shield could be bent up to clear
Just now, Jason240z said:
isn't that the old type header?
Nope, only fits my model exhaust, well fingers crossed:)
I'm afraid to say it is.
