Site will be going down for maintenance today
I bought this used splash pan a few weeks ago. It obviously needs to be cleaned up and painted. It would take some work to fabricate a pan with similar dimensions, but no one is making new pans that I'm aware of.
Robert S.
@disepyon
Build an undershroud that can be flat shipped, either riveted or bolted together that has a modern functional look and you will sell lots. Guys going for the OEM look will want an original piece anyways. Make it a custom unit, maybe out of stainless or powder coated and it will be a hit!
Also, keep in mind the splash pan for the '70 - '74 is different from the pan for the 74 1/2 - '78. I think you can still get the later splash pans from Nissan and the mounting holes are located slightly off from the early versions.
Robert S.
Sent from my HTC6545LVW using Classic Zcar Club mobile
@EhlersRS
If I may, what did a used splash pan run you?
For Iowa the condition isn't too bad. A little rusty on the inside near the back but no obvious really rotten areas
[mention=20033]EhlersRS[/mention]
Hey Patcon,
This pan came from a guy in NC and I think it was originally on a '73 model. I paid $100 for the pan and $30 for shipping. From what I've seen a pan in average to good condition will run around $200. After the pan arrived here, I noticed there is some pitting on the area you mentioned. I'll decide if it needs repair after blasting the rust off, otherwise I'll just repaint it.
Robert S.
Thanks,
Those numbers are similar to what I have seen too, and many of those are pretty well beat up. Yours looks pretty straight all things considered. You could also use a rust remover from Eastwood which will not remove any good metal, since the panel isn't really very thick anyway...
Thanks,
Thanks for the advice on the Eastwood product. These pans are definitely made from a thin gauge panel!
Robert S.
Interesting Ideas.  Will keep a list of your suggestions and hopefully to show up on my site someday soon. Keep them coming.
Managed to get the seat brackets finished. However as of yet these have not been approved yet for fitment. Once approved they are ready for purchase (https://www.prospect-d.com/). Can also review the installation guide as well in the install guide section.
Similar to the ones I made for my Z, already posted pictures. These appear to fit and made a lot better.
Pictures:
IMG_0776.JPGIMG_0778.JPGIMG_0780.JPGIMG_0781.JPGIMG_0807.JPGIMG_0811.JPGIMG_0812.JPGIMG_0815.JPGIMG_0818.JPGIMG_0819.JPGIMG_0820.JPGIMG_0821.JPGIMG_0823.JPGIMG_0824.JPGIMG_0825.JPGIMG_0827.JPGIMG_0828.JPGIMG_0830.JPGIMG_0831.JPGIMG_0833.JPG
Definitely think you will have a market for these. Very nice work
