August 17, 20168 yr comment_501223 What is it?  Sounds as though 26th needs one.  But nay, I could be misinterpreting that as sarcasm?  Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501223 Share on other sites More sharing options...
August 17, 20168 yr comment_501235 7 hours ago, Blue said: Crusty Rusty Bracket Anyone? Looks a bit like as battery hold-down clamp. If the early cars had the same rectangular frame as my car, this probably isn't Datsun or at least not 240Z. Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501235 Share on other sites More sharing options...
August 17, 20168 yr comment_501236 Well, unless I'm mistaken, that's a part you won't see very often because one of the parts it is made for has been replaced also. In all probability, you don't have that part either and the replacement doesn't fit that rubber grommet. No need to send it to 240Zrubbers because it is already reproduced. $40 You say it has no through-holes? What size is it? Take a picture of it with something that will show us size and scale. So let me ask you. The stuff 240Zrubbers sells is pretty expensive. Are you ready to spend that kind of money on a "proper" restoration? The S30 type Datsun was thoroughly tested and developed before any cars were manufactured and sold. It certainly was consistently developed and improved, over a number of years, but it would be inappropriate to say that "prototype" parts were initially used because the "production" components weren't delivered in time. What came on the early cars is what was intended. A lot of people claim a lot of things, but I have found over the years that if you haven't researched, if you haven't read everything you can get your hands on, if you don't speak Japanese (or know someone who does), you don't really know a lot about these cars. These are not American cars built exclusively for the American market (like many, many claim and I have heard some whoppers); these cars are Japanese imports.  Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501236 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501275 15 hours ago, 26th-Z said: Well, unless I'm mistaken, that's a part you won't see very often because one of the parts it is made for has been replaced also. In all probability, you don't have that part either and the replacement doesn't fit that rubber grommet. No need to send it to 240Zrubbers because it is already reproduced. $40 You say it has no through-holes? What size is it? Take a picture of it with something that will show us size and scale. No I don't think it is the two hole grommet. It has no holes and does not have a lip to cover the inside and outside of the fire wall. I'll take pictures shortly just to be sure. There was a merc part mixed in the pile as well as a B pillar emblem for a vent so not all the parts are from HLS30-000249. Here is the 2 hole on HLS30-00249. Well preserved under a lather of grease and graphite. This car is minty-mint once the crud is wiped off.  15 hours ago, 26th-Z said: So let me ask you. The stuff 240Zrubbers sells is pretty expensive. Are you ready to spend that kind of money on a "proper" restoration? Sort of a rude question but yes I am in this up to my neck and going deeper. Maybe I am a billionaire? For the moment I am just trying to collect all the right parts. I have a 72 that I plan to restore first.  Quote The S30 type Datsun was thoroughly tested and developed before any cars were manufactured and sold. It certainly was consistently developed and improved, over a number of years, but it would be inappropriate to say that "prototype" parts were initially used because the "production" components weren't delivered in time. What came on the early cars is what was intended. A lot of people claim a lot of things, but I have found over the years that if you haven't researched, if you haven't read everything you can get your hands on, if you don't speak Japanese (or know someone who does), you don't really know a lot about these cars. These are not American cars built exclusively for the American market (like many, many claim and I have heard some whoppers); these cars are Japanese imports.  HS30-H has educated us all on this and has made it clear. I am in agreement with both of you on this. Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501275 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501281 249 came with a ZX distributor fitted. Two spares were in the parts boxes. Here is one with no numbers engraved. Any ideas as to who made it or part number? Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501281 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501282 Here is the other distributor. The part number D614-52 is correct for an early 240z but the dual points seems off? Is this possibly a part for a Nov 69? Â Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501282 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501284 This fuel pump came with parts pile. The PO put a pressed steel clacker on it. Â Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501284 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501285 Here is the water pump in the parts pile. How to tell date? ATSUGI "13" Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501285 Share on other sites More sharing options...
August 18, 20168 yr comment_501286 Dual points are for an Auto, I think this is what a early orig water pump looks like. Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501286 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501287 13 minutes ago, 240dkw said: Dual points are for an Auto, I think this is what a early orig water pump looks like. Thanks! That looks unforgettable like something from a spaceship! Now I have to hunt.  I guess the distributor is not original then. I'll have to dig into the Zbarn for soemthing circa 69. btw I still have that chrome ring.... just been lazy and also back burner-ed.  Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501287 Share on other sites More sharing options...
August 18, 20168 yr comment_501289 I can wait, I still have my WP in a parts box. Decided to put a new one on instead of trusting a 40+ old one. Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501289 Share on other sites More sharing options...
August 18, 20168 yr Author comment_501295 Lucky Day! Found this in my parts heap. Looks like the correct one for 249. The one currently in 249 is the later type.  Link to comment https://www.classiczcars.com/forums/topic/55977-fun-parts-and-identification-help-needed-for-hls30-00249/?&page=5#findComment-501295 Share on other sites More sharing options...
