Float level advice, please. - Page 14 - Carburetor Central - Classic Z Car Club Skip to content
Are you turning the carbs upside down to adjust the floats? That is on the SU video from ztherapy but it doesn't work with the valves you buy nowadays. They were using Grose valves in that video. Those are built different and would not hold the weight of the floats while setting the gap between the float and the lid of the float chamber. The newer needle valves will not hold the floats up. I fought with this for a long time then made my own "float chamber" out of a clear glass jar and set them that way. That's been about 10 years ago and I haven't had to touch them since. They run great. I got rid of the lid with long ears and use two short ear lids essentially turning them from 3 screw carbs '71-'72 to early four screw carbs '70-'71.
Float level advice, please. - Page 8 - Carburetor Central - Classic Zcar  Community
Edited by siteunseen
9 hours ago, emptech said:
I like the idea of using a brass screw, either off the shelf or fabricated. I have a lathe, so I can fabricate the screws. What did the screws end up weighing?
Last time I messed with this, I tried to use off the shelf screws and I could not get enough mass packed into a small enough package. I've found that 4 grams is a good amount of mass to get the float to sit level at equilibrium, and the wood screw just didn't weigh enough.
Here's a failed attempt to use a brass wood screw instead of making my own weights from scratch. Pic of a wood screw chucked up in the lathe, narrowing the head, The process of narrowing the head worked fine, but the amount of mass remaining wasn't enough. I ended up making another pair of weights from scratch.
Here's a pic of what didn't work out:
I decided to go through all 14 pages of this thread. I spent many hours trying to get my fuel level in the bowl correct, whatever "correct" is. I even fabricated a plexiglass model of the fuel bowl so I could actually test the float in combination with the needle valves, which I know are NOT grose valves. I also found I was totally wasting my time by measuring the distance from the top lid of the fuel bowl to the top of the float, which we now believe was meant for grose valves. The critical measurement I've learned is the actual fuel level in the nozzle, not the bowl. Either .426" or 10mm would be the level of fuel below the carburetor bridge. That level happens to be based on the fuel level in the bowl, which is determined by how one bends the tabs on the float itself. Some of us have discovered that to get the proper fuel level, the float is actually too high in the bowl and is dangerously approaching the lid of the float bowl.
As you can see, CO has fabricated some brass screws that when inserted into the float will help the float attain the proper angle when the fuel level is correct. I have fabricated similar screws and will drill and tap holes in the float as CO did, and hopefully after re-adjusting the tabs will finally have the proper level.
I will report back with my findings, but from I've read from CO, I am expecting good results.
Jim
I've read that the mixture screws raise or lower the nozzles 1mm per revolution. One can raise the nozzles to the top and lower them 10 turns. At ten turns, the fuel level should be near the top of the nozzles.
  • 4 weeks later...
Mark:
I can't tell you how many hours I've spent on these carbs. I bought them used and had no idea how much the person I bought them from messed with them. I've spent many hours trying to get the fuel to the proper level in the bowls. I purchased some sight glasses from Z Therophy so I can actually see the level in the bowls, but I've found that is a waste of time. The best way I've decided is turning the nuts down 10 turns, 10 mm. Taking the domes off and letting the fuel pump fill the bowls, take a look down into the nozzles. I think I'm still about 2mm low, don't know how critical that is. I cannot start the engine. I can start it on ether but can't keep it running, I think it is still too lean. I need to get back to the float adjustment again.
If you have been following this thread, I added I believe 6 grams of weight to each float, so when at the proper level, the floats are level, not pressing against the tops. Again, I'll report back.
Jim
Can you post a picture of your floats? It should not look like a ramp, more like a hump.
They should look like this...
Not like this...
Bending float tab direction - 3 screw SU - Carburetor Central - Classic  Zcar Community
Not like this...
I'm getting very close, one carb at a time. One photo is the view looking down the nozzle, which has been set to 10 turns. Once there is fuel, I can shine a flashlight down the hole and see the level, I'm usually either too high or too low, trying to find that sweet spot. The other photo is the rear float, you can see the weight that was added so when the bowl is at the proper level, the float is level, not canted, where it would hit the ceiling of the bowl. There has been a lot of discussion on that in this thread. One of the photos shows the weights that were fabricated.
BTW, although the carbs are from a 240z, they are being installed on a 260z, getting rid of the flat tops.
Jim emptech@surewest.net
I think my tab looks too much like a hump, so what happens is the bowl is filled to almost the right level, viewed from the nozzle. I bend the tab down slightly to allow a bit more fuel to flow and it overflows. I think the shape needs to be more of a ramp than a hump, I think what happening, the float gets to almost the right level, I bend the tab down a bit and suddenly the bowl over flows. I think the needle valve goes over the hump. I'm going to try to slightly straighten out the curve.
My email is emptech@surewest.net I read it often, don't see this site all the time. Jim
I finally got the fuel level with the jet while turned 10 turns down, I then returned to what people recommend as a starting point, 2.5 turns from the top. With the choke on, will only run on starting fluid. The only thing I haven't tried is fresh fuel, Ive been using fuel I keep for my lawn mower, haven't tried new gas.
Ideas? Jim
It would be fascinating to know the how Skinner-Union (way back in the middle of the last century) came up with the bendable-tang-with-a-curved-ramp solution for closing the float chamber outlet valve. Maybe they adopted it from the shut-off scheme used in somebody's toilet tank? 😄
It would all be so much easier if there was an adjustment screw. An external screw would be nice, but even an internal screw would be an improvement.
I've often wished that someone would do a plot of the geometric relationship of gas level vs needle valve displacement, so that the effects of bending the tang at its fulcrum could be properly understood. One might also take a look at the effects of changing the tang's radius of curvature. Any volunteers?
Now that I have confidence in the float levels, I'm still having a problem getting the engine started. Next step is brand new fuel. A reminder, I removed the 260z flat tops and replaced them with 249z carbs. I read the thread about the nail in the carb, I need to takea step back to see what I missed. Hate to say, the car ran fine with the flat tops, I have to remember, if it's not broke, don't fix it.
When I run the engine with a puff of ether, it caughs and sputters, not getting fuel, sounds too lean. I was hoping the bowl level would have fixed it. Somebody had messed with the carbs before I got them.
Ideas?
Is the return restricted on the flat tops like it is on my '72? Easier saying, does the fuel rail for flat tops need changing to the one that is for 3 screw domes? Did you change the fuel rail? Maybe they are different.
