Skip to content
1973 Rebuild
Well, I screwed up. I bought a three-tube fuel rail instead of a two-tube one because I didn't stop and think about the fact that I might need to match it to the setup I am putting together.
I'm not sure if it's for a '73 or a '74. Gotta investigate.
Either way, I need to decide if I want to modify this one or buy another one with two tubes.
Bummer.
This is my rear main cap and the pieces that fell off while cleaning it up:
Cleaning all these parts up by chamfering the threaded holes on the block and head - so that torquing the parts dosen't "pull" the threads:
And some other shots of the various threaded holes (note the cleaned block):
Casting flash on the crank case will be ground away:
Tape being applied to all of the journal surfaces before any work is done:
Edited by Matthew Abate
Update on the engine:
  • Finished the crankcase grinding, cleaning, and painting
  • Got the front oil gallery plug out and tapped the hole
  • The paint looks very nice. Sprayed the cleaned block with prep-sol to remove oil residue, blew it dry with compressed air, then did the same with 99.9% alcohol
  • Gave it two very light coats and one medium coat of light-grey ceramic engine primer paint
  • Waited 20 minutes and used same method with the blue. Used less than 2/3 of the can.
On 1/23/2017 at 1:02 PM, Zed Head said:
Are you going to coat the inside with Glyptal like some people do?
We are still researching the right direction for the interior, but have had good results with other solutions, such as Rustoleum Ceramic Enamel, which doesn't need to be baked on.
In other news... Freeze plugs:
And luscious Nissan blue paint on the block:
More angles:
Progress:
We went with Rustoleum Ceramic Enamel on the interior. This did very well in a '63 'Vette, so we're confident.
Cleaned it out:
IMG_4251.thumb.JPG.7bbc0dae182b3e4956602
IMG_4252.thumb.JPG.ea5a58323497b3df7b530
IMG_4253.thumb.JPG.1c452c312da8e1e84900a
IMG_4254.thumb.JPG.edcb22a2106484819ee33
IMG_4256.thumb.JPG.59d3cdb281058b400968d
Finished with the plugs:
IMG_4255.thumb.JPG.c3e1d80a1cf9b04fd602f
Painted the inside:
IMG_4257.thumb.JPG.c50e06d78042b289a4f07
IMG_4258.thumb.JPG.da36a2f4fd87bc2f70075
And took a look at the parts for the intake setup:
IMG_4259.thumb.JPG.6487a65f51f2fc32b921d
IMG_4260.thumb.JPG.855fa3d2d56f2fd8191f7
IMG_4261.thumb.JPG.37edddb1db89841d24bd1
Not sure what to do about accidentally buying a three-tube fuel pipe / rail...
FYI Glyptol's site says bake or air dry for all but their catalyzed paint...
50 minutes ago, Patcon said:
What are you doing to do with the rear main cap?
The damaged area was ground away and the threads were chamfered. What you see below is the cap "in-work". More chamfering was accomplished and the oil seal drain area was smoothed and polished out. Nothing wrong with it because what was ground away doesn't affect the strength of the cap.
Yeah I think baking would be a required step for the interior paint? Would hate for a chip of paint to clog an oil passage.
It turns out that the stains from forty years of grease and road grit on the various aluminum parts aren't coming out.
I'm looking into different solutions like oven cleaner, Never Dull, Aluma-Brite, and such, but if nothing works we are going to be forced to go with paint because I don't want to polish it.
