June 23, 201411 yr comment_450326 This is incredible. I am very, very jealous! Thanks for sharing your re-build. Looking forward to seeing how this goes The car looks great. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450326 Share on other sites More sharing options...
June 23, 201411 yr Author comment_450331 i believe the sway bar should rotate freely in its bushings, so it wouldn't present any resistance to the car settling.are you sure the springs are set correctly in the perches? also, are you sure you have the correct springs (front in front, rear in rear)? Yea I triple checked the placement of the springs. The longer ones are in the rear. I'll wait until the motor is in before I worry about it. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450331 Share on other sites More sharing options...
June 23, 201411 yr Author comment_450332 This is incredible. I am very, very jealous! Thanks for sharing your re-build. Looking forward to seeing how this goes The car looks great. Thanks man! Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450332 Share on other sites More sharing options...
June 24, 201411 yr comment_450345 I wouldn't worry about the height yet.No glass or seats or anything else in the interior for that matter. What about gas tank and differential? Spare tire?I'm thinking you're going to be adding hundreds of pounds before your done, so I wouldn't worry until you have it loaded and then see where you're at. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450345 Share on other sites More sharing options...
June 25, 201411 yr comment_450411 Yea I triple checked the placement of the springs. The longer ones are in the rear. I'll wait until the motor is in before I worry about it. I've heard that once or ten times before! If they're Eibachs, look at the part numbers on the springs. The ones ending in .001 go in front and .002 in back. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450411 Share on other sites More sharing options...
June 25, 201411 yr comment_450444 I'm running Eibachs and my car isn't sitting anywhere that high. Like others have said, check the part numbers, fully assemble the car, then see where you're sitting. I installed mine, then checked the part numbers and realized I had them in backwards. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450444 Share on other sites More sharing options...
June 25, 201411 yr Author comment_450448 Yea the springs with the .01 # are up front. I'm sure once it's assembled and the motor is back in it will sit nice. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450448 Share on other sites More sharing options...
June 27, 201411 yr Author comment_450533 Got some stuff installed in the engine bay. Horns Inspection light Hood latch and misc.. Pedal box and steering wheel painted and installed. (new steering wheel coming) New Muteki black wheel lugs Also just ordered: Brake booster Brake master cylinder Clutch cylinder Speedometer cable New engine mounts Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450533 Share on other sites More sharing options...
June 27, 201411 yr comment_450544 dash goes on then the bolts for the steering column holder... don't tighten too much now Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450544 Share on other sites More sharing options...
June 28, 201411 yr comment_450576 Hazmatt, you are doing great work, don't worry about the height of the wheel arches. Once the engine/tranny are in things will even out more and you will be surprised how much the weight of the interior fittings affect the stance.The detail is superb! But with that white engine bay I can see how your weekends are going to be spent once she is on the road.Chris Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450576 Share on other sites More sharing options...
June 28, 201411 yr Author comment_450578 dash goes on then the bolts for the steering column holder... don't tighten too much now Yes, thanks. I needed to temporarily mount it so I can wheel it around. Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450578 Share on other sites More sharing options...
June 28, 201411 yr Author comment_450579 Hazmatt, you are doing great work, don't worry about the height of the wheel arches. Once the engine/tranny are in things will even out more and you will be surprised how much the weight of the interior fittings affect the stance.The detail is superb! But with that white engine bay I can see how your weekends are going to be spent once she is on the road. Chris Beats the hell outta cleaning the house LOL Link to comment https://www.classiczcars.com/forums/topic/49193-my-datsun-280z-rustoration/?&page=10#findComment-450579 Share on other sites More sharing options...
