Thanks guys. I spoke with Bruce and sent Roger an email. That is a good idea on the cable, and probably the quickest and the lowest cost solution, but I am inclined to get a working mechanical solution.
It can be figured out, here are some differences I ran across:
Top yellow line: different lengths depending on the lever to the right, can be adjusted.
2nd yellow line: same bracket, some have 20mm spacers behind depending on the length of
3rd yellow line: this rod, different lengths depends on which balance tube being used
4th yellow line: should be attached to above
5th yellow line: different lengths depending on carb spacers
I was lucky enough to have plenty of parts to choose from to make my carb swap work.
Bonzi Lon
Hey Bonzi, I think that no matter what, I will need to be doing some cutting and welding to get the lengths right. Hopefully one of the sources I am pursuing will come through.
