Sure, just undo the bolts behind the front bumper overriders, turn them the right way up, and put the bolt back on. Then theres that non standard side mirror, the holes from that will have to be filled.
Other than that the car looks great. :)
(p.s. Ok i know you really mean the flares. Why would you want to remove the Nice factory ZG flares? Just buy a z that doesn't have them. If they were fitted properly, ie. to allow wide wheels to used, the guards would have been cut out, which means an expensive time at the pannel beaters welding in new wheel arches.)
https://www.classiczcars.com/forums/topic/14769-reversal/#findComment-110174
unsure if fenderwells were trimed or not. what's with the front bumper guards-look kinda funny. bambi-if link doesn't work go to Zcar.com classifies-check out green 73 for sale
https://www.classiczcars.com/forums/topic/14769-reversal/#findComment-110177
zhead240: when I go to zcar.com, I find the classified ad, but I don't see a picture there. I think that I've had this problem with zcar.com before. Can anyone post the pic here so I can see it?
https://www.classiczcars.com/forums/topic/14769-reversal/#findComment-110183
Thanks Will!
Thats a nice looking car! Photographs well anyway. Definitely looks like the the bumperettes are on upside down, and from the looks of the tires and wheels, I'd bet a Happy Meal that the sheetmetal has been carved to allow them to fit. Also looks like there are no center cap on the wheels. Description says 8" wide Front wheels, and 9" wide Rears.
But, still it looks like a very nice car. Need detail pics of the "standard problem area's" though to know for sure. "No rust to be concerned with." $hit, IMO any rust should be a concern (to a greater or lesser extent). I sure wouldn't ignore it. Wonder how bad the "issues" with the new paint really are?
https://www.classiczcars.com/forums/topic/14769-reversal/#findComment-110186
wouldn't opening the hood give you the hint that the bumper guards are upside down?looks like they'd rub.
My 73's are on upside down, bought it that way, the hood doesnt rub, I'd like to flip them but I can just see the studs snapping off as soon as I attempt it.
Someday I'll get brave and turn them around.
Chris
https://www.classiczcars.com/forums/topic/14769-reversal/#findComment-110232
