Picked up a 78 280z today. PROS & CONS with some Pics. - Page 17 - Open Discussions - Classic Z Car Club Skip to content
@Patcon Good point. I'll add leakdown test to my to-do list.
@Zed Head Regarding the fuel pressure, I agree. It's acceptable for the time being, focus on the bigger priority.
@Zed Head Yes, vacuum advance is connected to ported vacuum on the TB. Yes, carbon canister valve is teed into the same ported vacuum advance line. Carbon canister valve is suspect, so I plugged the hose for the time being. Made no discernable difference to manifold vacuum reading.
BUT...a discovery!
parks and rec what GIF
For the heck of it I decided to remove the air filter box and manually move the AFM flap with my fingers. And we have some improvement. I was able to bring the vacuum into the green zone and get 18 in Hg.
HMMM, correct me if I'm wrong, but this would indicate that I'm actually running lean, not rich. Is that right?
This would also seem to line up with other people experiences that these systems tend to drift leaner over time.
If that's the case, I assume the next step would be to remove the AFM and run through the FSM test procedure. And if it's outside of spec, I assume my only option is to adjust the internal spring as described on the AtlanticZ site. Sound reasonable?
And lastly, would it make sense to just do the potentiometer mod now to add more tunability, or hold off on that? I would use the type that is adjustable, allowing me to dial in a range from zero to max. I assume it can't hurt anything, especially if it can be set at zero if not needed.
I made a video of everything I just described here to see for yourself: https://youtube.com/shorts/J5XBSgVT6jo?feature=share
I would just go directly to the potentiometer. It's simpler and more precise, I'd guess, than adjusting the spring. Plus, adjusting the spring doesn't increase fuel at full AFM vane opening. It just lets the vane get there faster.
Good idea on using the AFM to richen things up. I'd forgotten about that.
I did notice that your idle RPM is lower than spec but it probably doesn't matter much. The automatic is at 700, but it's in Drive, under load.
I agree, Noticed as soon as you increased idle just a bit you got into the range. Bump it up on the idle adjustment
