Can anyone confirm that this is air filter assembly is from an early 240Z? It looks similar, but is missing some of the inlet/outlet barbs that I think it should have? Could it be from a different Datsun model altogether?
I'm looking to purchase these, but want to make sure they are for a Z before pulling the trigger.
Thanks in advance for any input!
Thanks for the link! The one I pictured appears to be the same as the one on the far right of the three pictured by 26th-z. It only has one "hose barb" connection.
Thanks Again!
Yes, I have those air cleaners, accumulated over the years. I don't know what or how that style of cleaner fits.
The float bowl drains don't have to connect to the backing plate. I have seen drain tube fittings just straight down from the float bowl. Let me see if I can find a picture.
Edited by 26th-Z
