20 hours ago20 hr comment_676504 Brake line is quite different than the bleed system. IMO go back and do it by having that bleeder open. You might be going down a rabbit hole here. Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676504 Share on other sites More sharing options...
20 hours ago20 hr Author comment_676506 1 minute ago, Yarb said:Brake line is quite different than the bleed system. IMO go back and do it by having that bleeder open. You might be going down a rabbit hole here.Haha, rabbit hole for sure. Sitting on the bench, with the caliper taken apart in 2 pieces, the brake pads "piston" ought to be able to compress without having to open the bleeder, correct? The fluid should go back the way it came from. Anyway, how hard should it be to move the piston? Can you compress it by hand or do you need a C clamp like I did? Edited 20 hours ago20 hr by Parman Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676506 Share on other sites More sharing options...
20 hours ago20 hr comment_676507 Did you open the bleeder?? Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676507 Share on other sites More sharing options...
19 hours ago19 hr comment_676508 There is still fluid in that assembly. Did you blow everything out with compressed air? Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676508 Share on other sites More sharing options...
18 hours ago18 hr comment_676509 Most calipers I've worked couldn't be collapsed by hand and my hands are pretty strong. Have the calipers been rebuilt? Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676509 Share on other sites More sharing options...
18 hours ago18 hr comment_676511 1 hour ago, Parman said:Sitting on the bench, with the caliper taken apart in 2 pieces, the brake pads "piston" ought to be able to compress without having to open the bleeder, correct? TNot sure what you mean by two pieces. But if it's sitting on the bench then, obviously, there's an open port to atmosphere. No way to hold pressure.The piston should be easily moved by hand if the caliper is new or newly rebuilt and has had fluid in it. Or maybe not, re above. Where did you get the calipers? Might have a bad rebuild. Tight seals. Edited 18 hours ago18 hr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676511 Share on other sites More sharing options...
18 hours ago18 hr comment_676512 If you have a caliper on the bench you might as well pop the piston out. Don't scratch the cylinder with the metal dust seal retaining ring.Images won't load but the Brake chapter describes it.Uploading Attachment...Uploading Attachment... Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676512 Share on other sites More sharing options...
18 hours ago18 hr comment_676513 Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676513 Share on other sites More sharing options...
1 hour ago1 hr Author comment_676527 I very much appreciate all you guys. I believe they are the original calipers, I rebuilt them. When I had the one on my bench, I tried blowing the piston out of the inside half with compressed air, but trying to hold my fingers over the 2 holes leading to the other half, I didn't like where it was going, so I stopped. Never did move the piston out. I may have not assembled them right, lack of grease possibly, I don't know yet. I have my first car show locally tomorrow 15 miles away, so rather than break this system apart now, I'm going to wait until next week. Then I'm going to disassemble a caliper and see why those pistons are so hard to move. Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/?&page=2#findComment-676527 Share on other sites More sharing options...
