Front Brakes dragging - Page 2 - Wheels & Brakes - Classic Z Car Club Skip to content
Brake line is quite different than the bleed system. IMO go back and do it by having that bleeder open. You might be going down a rabbit hole here.
Haha, rabbit hole for sure. Sitting on the bench, with the caliper taken apart in 2 pieces, the brake pads "piston" ought to be able to compress without having to open the bleeder, correct? The fluid should go back the way it came from. Anyway, how hard should it be to move the piston? Can you compress it by hand or do you need a C clamp like I did?
Edited by Parman
Did you open the bleeder??
There is still fluid in that assembly. Did you blow everything out with compressed air?
Most calipers I've worked couldn't be collapsed by hand and my hands are pretty strong. Have the calipers been rebuilt?
Not sure what you mean by two pieces. But if it's sitting on the bench then, obviously, there's an open port to atmosphere. No way to hold pressure.
The piston should be easily moved by hand if the caliper is new or newly rebuilt and has had fluid in it. Or maybe not, re above. Where did you get the calipers? Might have a bad rebuild. Tight seals.
Edited by Zed Head
I very much appreciate all you guys. I believe they are the original calipers, I rebuilt them. When I had the one on my bench, I tried blowing the piston out of the inside half with compressed air, but trying to hold my fingers over the 2 holes leading to the other half, I didn't like where it was going, so I stopped. Never did move the piston out. I may have not assembled them right, lack of grease possibly, I don't know yet. I have my first car show locally tomorrow 15 miles away, so rather than break this system apart now, I'm going to wait until next week. Then I'm going to disassemble a caliper and see why those pistons are so hard to move.
Where did you get the parts?
The grease is for inserting the seal in to its groove. Brake fluid is for sliding the piston through the seal.
Oh well, the cars wouldn't be any fun if there wasn't something to fix on them.
In other caliper rebuilds mainly on the Toyota big brake option for Z’s. I went and found plugs that would block ports that were letting air disperse in order for the piston to blow out. If I may ask have the pistons been removed?
I drove it about 15 miles to the car show, never touched the brakes, just used the E-brake. Front wheels were heated up some. Got home and they were both about 170-180°.
I took apart the calipers, they seemed okay. Very hard to remove a couple of the pistons. Oiled them up and reassembled. Checked the wheel bearing rotation starting torque with my fish de-liar. 20250610_214250.jpg
They were both way too tight. Replaced the grease in the wheel bearings with fresh grease and torqued them correctly this time. Went for a drive, problem solved. Wow, fun car!
