Posted Yesterday at 12:50 AM1 day comment_676481 I finally got the exhaust on my car and took it for a drive. After about 15 miles, the front brakes are getting hot. After it cools down, they're both free-ish, slight dragging. Leaving the lines on the master cylinder, I pulled it away from the master-vac. Then screwed the push rod in a ways. I also adjusted the clevis on the brake pedal a couple turns. Took it for another drive today, trying not to hit the brakes, after about 15 miles, got home, jacked the front of the car up, brake pads are tight against the rotors, both left and right. Ugh. Both the master cylinder and master-vac were rebuilt. I did put new pads after restoring the calipers. Whatever it is, it's affecting both left and right brakes equally on the front. When I found this car, it had a later master cylinder on it, with a long tip on the push rod. When I tried to bolt the older correct master cylinder on, it wouldn't fit, the push rod was too long. Fortunately, I had the master-vac that had the shorter push rod in it. I thought I measured everything right, and it bolted up. Anybody got any suggestions? I don't like spilling brake fluid on fresh paint! Why aren't those calipers retracting? Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/ Share on other sites More sharing options...
Yesterday at 01:14 AM1 day comment_676485 If the fluid can't flow back and there's any air in the system they will get tight when driven Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676485 Share on other sites More sharing options...
Yesterday at 01:54 AM1 day Author comment_676488 So are you saying it could just be air in the system? Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676488 Share on other sites More sharing options...
Yesterday at 03:52 AM1 day comment_676491 I believe that’s what he was referring to. Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676491 Share on other sites More sharing options...
Yesterday at 04:32 PM1 day comment_676492 15 hours ago, Parman said:Leaving the lines on the master cylinder, I pulled it away from the master-vac.If you can do this when the brakes are stuck it will tell you if the rod from the booster to the MC is too long, causing the return port in the MC to be blocked. You'll have to do it while things are still warm though. Patcon is implying that the air expands as it gets warm creating pressure in the system.They make a tool for setting the booster rod length. It's a fairly common problem, especially with rebuilt boosters.If you stare at the parts long enough you can figure out other ways to get it right. Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676492 Share on other sites More sharing options...
21 hours ago21 hr Author comment_676496 I appreciate all the info. I removed one of the calipers and to compress the pistons, I needed to use a C clamp. Is this normal? Seems like they're awful hard to move. It takes alot of pressure to get them to move one way or the other. So when a guy applies the brakes, then releases the brakes, there's no spring to make the pads retract, they just kinda ride along the rotor. This drag is causing things to heat up and expand, making it tight. Some Fords have springs in the calipers to make them retract. I applied the brakes while the front end was lifted up, it wasn't heated up. After releasing the pedal, there was a more noticeable drag on the rotors. I pulled the master cylinder away from the master-vac, and there was no change. I don't think that's the issue. Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676496 Share on other sites More sharing options...
21 hours ago21 hr comment_676497 Was the bleeder open when you tried to push the piston in? Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676497 Share on other sites More sharing options...
21 hours ago21 hr comment_676498 The Nissan calipers use the rubber seal to retract the pistons.One common cause of sticking caliper pistons is collapsed rubber hoses. The MC can generate high pressure to push through the collapse but the rubber seal cannot to allow the pressure to release. It becomes like a check valve. On some cars the cause is a metal clamp on the hose that rustjacks and pinches the hose. But just degrading internal material can cause it also. I ould guess that a kink in the hose could cause it also. Edited 21 hours ago21 hr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676498 Share on other sites More sharing options...
21 hours ago21 hr Author comment_676499 No, I don't think so. But the line was disconnected.It has new rubber hoses, so don't think that's it. The hole in the master cylinder, that creates the pressure when you hit the brakes, is this also the return hole for the fluid? Edited 21 hours ago21 hr by Parman Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676499 Share on other sites More sharing options...
21 hours ago21 hr comment_676500 But, don't overlook the brake pressure warning switch. Or the NP valve. Can't remember the car. (https://www.classiczcars.com/settings/signature/) It can get gummed up also.Uploading Attachment...Uploading Attachment... Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676500 Share on other sites More sharing options...
21 hours ago21 hr comment_676501 Probably worthwhile to read the Brake Chapter. It's not long. Well-illustrated. Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676501 Share on other sites More sharing options...
21 hours ago21 hr comment_676502 Opening the bleeder when the brakes are stuck will tell you if the problem is pressure in the caliper or something else. If there's pressure in the caliper you can work your way back to the the MC fitting by fitting. Or work your way down, from the MC. First you need to know if it's hydraulic pressure or just mechanical sticking. Edited 20 hours ago20 hr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/69416-front-brakes-dragging/#findComment-676502 Share on other sites More sharing options...
