Skip to content
Gasoline vapor sniffer device
The FSM has a drawing, below.
It's not clear how you're using this vapor detector device.  I think that the most common source of gasoline smell, that's hidden, is the bottom of the charcoal canister.  The carbon/charcoal gets clogged over time and does not absorb all fo the vapor.  The bottom of the canister is open to the atmosphere.  That's where I'd be looking, after I tightened all fo the clamps.
Gotcha - thanks for the picture, I will keep the clamps at the top.  A friend is bringing over the socket I don't have to tighten these and then we should be good to go - I'll check the carbon canister after that for sure.
Regarding the sniffer, I pull the oil pressure switch plug and set the key to 'on' to pressurize the system.  I then turn on the sniffer and move its bendable head to each spot with a rubber hose and clamp.  It beeps and shows the concentration on the screen when it notices fuel vapors.  The device is pretty impressive.
Update: Cranking down the final injector clamp (ended up using a 1/4 inch socket with a u-joint, and an extension.  The car doesn't smell anymore and the sniffer isn't picking anything up.  I tested the device just to be sure by opening the fuel door and it smelled fumes by the gas cap (I didn't remove the locking gas cap).
Looks like case closed 🙂 - thanks all!
  • 7 months later...
I have recently fallen in love (metaphorically) with a smoke machine lately. Very good at finding leaks. Used it on gas tanks….
Mine has an internal compressor that build lots of psi in the system of choice. Reasonable affordable. Uses mineral oil. Bit hard to see small amounts of leaking smoke, have to use a bright light and lots of different viewing angles, it doesn’t make the huge volumes of dense smoke I expected, but still very effective.
I also envisioned using a thermal imaging camera at the same time to show a visual map of the leak location, will report on that some day.
6 hours ago, Evan Paul said:
Bot, bot, bot, bot
Hey @Mike , Here's another bot. They are still multiplying.
I reported the post above, but still not sure the report function is working. There are other bots I've reported that are not yet nuked so I'm not sure if I'm doing this right.
